| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
#46
Re: Novitec Rosso Ferrari 599
I love the extra detailing your giving this ferrari. Don't stop.
#47
superb!
i seriousy think that you're a pro modeller now.. ![]() don't you have a day job? it will take me forever to reach that level |
#48
midmazar, thanks
![]() ben, car modeling can't make a living in malaysia, i think u should know that i work in advertising, i can do what ever i want when i'm free, but not modeling
#49
wow this is beautiful keep it up
#50
small progress on the body, the door handle look fake
![]() so i carefully thinned down, using chisel and needle ![]() primed, look better now ![]() ![]() side vent, after sanding & puttying, some holes & scratches are visible but i decided to cover that after priming, easier to see ![]() ![]() after 2 round of priming & careful sanding, this is what i got, looks ok but not perfect ![]() ![]() also primed the whole body with mr surfacer 1200 ![]() ![]() ![]() ![]() comments are welcome |
#51
Looking really good! What color is it going to be?
#52
Even in primer it is looking fantastic cant wait to see the color!
Check out my Youtube Channel for Video's of my builds and some tips and tricks http://www.youtube.com/user/xrcflash https://www.facebook.com/thescalemodelingchannel My online webshop www.thescalemodeler.com |
#53
intended to use mr color super white iv (156), but i'm not sure is it a match for bianco avus
#54
How did you apply the Mr Surfacer? I have some but am not sure if it can go through an airbrush
I'm not a complete idiot, some parts are missing. |
#55
i use tamiya HG spray-work III 0.3mm airbrush, thinning ratio is 1:2.5 (1 surfacer : 2.5 thinner) yes, its quite thin so i usually need at least 3 coat but the result is smooth
#56
As, I say before great job.
I don't stop to watch it, again and again... By the way, what thinner are you use for Mr Surfacer? It's tamiya x-20 are suitable? Thanks for sharing. |
#57
nope, X-20 is enamel thinner, Mr Surfacer is lacquer base, I use Mr. Thinner or Gaia thinner, both are lacquer thinner
#58
Great work. Seats are awesome and so realistic, i like them.
Max |
#59
Simply amazing work. You make it sound very easy with this. You can be sure that I'll be accompanying for a day who know how to make one too. Congratulations, keep posting.
#60
thanks guys for the encouraging words,
some updates, but not too progressive as i'm busy with work recently the rear lips, first trace the shape from the rear diffuser, then cut out from 0.5mm styrene, i draw line to mark the bending line ![]() clamp it, blow with hairdryer to soften the plastic so i can bend it without breaking the thin styrene ![]() slowly bend it to get the right shape ![]() rough shape ![]() unfortunately 0.5mm is correct thickness but TOO fragile to work with, and i should NOT use thin cement as it weaken the styrene and break it, actually i break it more than 3 times, i think i've to redo in thicker styrene and slowly thin it down ![]() ![]() frustrated, i continue other easier parts, the side vent is too shallow if looked from the side, so i add some styrene sheet to make it deeper ![]() reinforce inside, also it's easier for me to position & glue the mesh later ![]() and the rear spoiler is almost done, but i felt the shape is incorrect and too small ![]() ![]() ![]() ![]() ![]() ![]() the spoiler bracket is made from leftover sprue runner, as i felt the styrene sheet that i had is too soft, first i drill holes, then slowly sand to get the right shape, then i cut it out and slowly sand to get the correct size and fitting, very difficult to get everything glue symmetrically if there's a slight dislocation, as you can see, the position i glue is not centralise and slightly towards the right side. comments are welcome
