Old 06-26-2019, 03:19 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: SERIOUSLY OT: Calling all chicks! IT'S PART 6!!
Originally Posted by Killa_CRX View Post
Also... my back yard is covered in poison ivy... who wants to come help me destroy it all?
Adrian said he would do it, if you let him wear a Speedo the whole time.
Old 06-26-2019, 04:39 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
That speedo would get lost in the folds
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-26-2019, 04:42 PM
BLU CIVIC's Avatar
調整器
Wife is finally on board with opening my own shop. Last night I showed her the repair order for the car I just replaced the evaporator core in. By this morning, she was sending me facebook and craigslist links for used/for sale A/C machines ... still have to decide on a corporate name, before I start taking on side work.
My wife's M35 needs some a/c work done. Replaced the compressor with a used unit and had a guy who we thought was going to be our mechanic work on it. We bailed on him when he started acting sketchy and Pep Boys said the it that the whole system needs replacing, minus the compressor.
The name's Adrian
2011 CR-Z - Stock
Old 06-26-2019, 06:18 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
What exactly was/is it doing?
LoL@ Pep Boys... "If we replace the whole system, we don't have to figure out what's actually wrong!"
Although, as expensive and extensive as things like the evaporators are, that's bad enough, labor wise. Evap is expensive, because everything down to the firewall has to come out, on most modern cars.
I've got another evaporator on a 4Runner lined up for tomorrow
Honda Enthusiast
Old 06-26-2019, 06:22 PM
Killa_CRX's Avatar
When Civics Attack!
Honda Enthusiast
Old 06-27-2019, 02:53 PM
BLU CIVIC's Avatar
調整器
Said it's leaking from multiple spots. Not much detail given after that
The name's Adrian
2011 CR-Z - Stock
Old 06-27-2019, 02:56 PM
BLU CIVIC's Avatar
調整器
I don't swing that way young man
The name's Adrian
2011 CR-Z - Stock
Old 06-27-2019, 04:21 PM
Killa_CRX's Avatar
When Civics Attack!
Whoa.... The picture I linked to changed, wtf? LoL that's EXACTLY what I posted
Honda Enthusiast
Old 06-27-2019, 04:27 PM
Killa_CRX's Avatar
When Civics Attack!
Never leaks from multiple spots. Picks a weak spot and leaks from there. Usually given away by the oil that leaks out with it, which is why we usually charge it with some special dye and then look for the leak. There are also other tells to look for.
Kinda screwed to see, if it's leaking at the evaporator, because it's so hard to see. I've got in the habit lately of snaking a bore scope into the evap case to check for oil buildup or corrosion.
Honda Enthusiast
Old 06-27-2019, 04:32 PM
BLU CIVIC's Avatar
調整器
Huh?
The name's Adrian
2011 CR-Z - Stock
Old 06-27-2019, 04:39 PM
BLU CIVIC's Avatar
調整器
We've spent too much money on it trying to get the a/c right and currently fine with putting freon in when necessary.
The name's Adrian
2011 CR-Z - Stock
Old 06-28-2019, 05:51 AM
Killa_CRX's Avatar
When Civics Attack!
Huh?
https://media.giphy.com/media/3oEjHV...HBCw/giphy.gif
I copied a link from an image search, and the linked image changed somehow
Honda Enthusiast
Old 06-28-2019, 06:10 AM
Killa_CRX's Avatar
When Civics Attack!
I completely understand. There are issues with that. As freon leaks, it carries oil with it. Once the compressor dries up, it'll lock up just like a motor.
So every now and then, some oil needs to go back in with the freon. But not every time, because an oil flooded system doesn't cool either.
As a matter of fact, most of the times I ever replace compressors that aren't just really, really high mileage on any Toyota or Lexus (except RX350's), is caused by people who just keep adding freon and oil starve the compressors. That gets expensive, because before it locks up, it usually starts sending metal shards down stream through the condenser and dryer, sometimes they last long enough to clog the expansion valve. That results in having to change out the evaporator, condenser, expansion valve, dryer, and flushing all the lines.
Not trying to make a sale, just keeping you informed
Honda Enthusiast
Old 06-28-2019, 09:20 AM
BLU CIVIC's Avatar
調整器
It shows the same gif
did not realize that. Thanks for the info
The name's Adrian
2011 CR-Z - Stock
Old 06-29-2019, 07:10 PM
Forunn Daberator
Hahahahahah... nice work there. Never trust a moderator....
Also, this thread hasn't seen this much action in years.
P.S. Yaymorestorms.
