Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-15-2009, 09:28 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Ned's 91 GSX
That one looks fine. Just dont go with any thing cheap and you will be fine. Fuel lab and aeromotive seem to be the most popular. Now for installing it on a 4g63 I have no idea. Im guessing its going to be pretty hard on your car seeing how your fuel pump was so rusted/corroded and Im sure you probably have screw line connections like the 420a does, goog luck.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
  #32
Old 11-15-2009, 09:57 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Ned's 91 GSX
On the 4g63 it's not too bad. You just run the rubber fuel lines to the unit which is a piece of cake and then run the SS line from the unit to the fuel rail. Then of course a vacuum line. Ideally, should be piece of cake.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
  #33
Old 11-15-2009, 10:41 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Ned's 91 GSX
Would I reuse the same vacuum line thats already on the stock FPR?
  #34
Old 11-15-2009, 10:54 PM
Holset powered 420a
Re: Ned's 91 GSX
You can as long as its still good.
98 Eclipse GS Turbo
2001 BMW 325i - DD
  #35
Old 11-15-2009, 11:51 PM
ned032002's Avatar
Re: Ned's 91 GSX
Well the stock fpr seemed to work fine so I could only assume that the vacuum line works fine.
  #36
Old 11-24-2009, 12:03 PM
ned032002's Avatar
Re: Ned's 91 GSX
So looking into a EGT setup. Not sure what temp range I'm looking for, the ones I'm looking at are some Glow shift brand ones. Here's what I mean by temp range.
http://www.glowshiftdirect.com/white...e-gauge-2.aspx
http://www.glowshiftdirect.com/white...ure-gauge.aspx
and also a wideband from them too, but concerned of reliability? any thoughts
http://www.glowshiftdirect.com/White...uel-Gauge.aspx
  #37
Old 11-24-2009, 12:31 PM
david-b's Avatar
Dave is THAT guy
Re: Ned's 91 GSX
I have one of the Glowshift EGTs. Never had a problem with it. I was only seeing like 1200* tops on where it was at on the n/t setup. It's not installed on my new DP because I couldn't find a bung for it. But never had any issues with it. I would go with the 2400* one.
Never heard anything about the WB from them.
75 Monte Carlo
  #38
Old 11-24-2009, 03:00 PM
Holset powered 420a
Re: Ned's 91 GSX
Yea I would get a different WB. Something that you know works good and is accurate. I have never heard of anyone using this WB and I would be concerned with the accuracy of the unit. Also its not even that much cheaper, other WB are only a couple dollars more.
As for the EGT gauge, I would try to find one around 2000F. I hit about 1600F under high boost so you will want one to go to atleast 1600F.
98 Eclipse GS Turbo
2001 BMW 325i - DD
  #39
Old 11-24-2009, 09:39 PM
ned032002's Avatar
Re: Ned's 91 GSX
This may sound dumb but doesn't a EGT just help with finding the right AFR by watching the temp under certain conditions? Won't it just be redundant if I'm getting a WBO2 cause that will tell me exactly what AFR I'm at? Pardon my ignorance but learning as I go!
  #40
Old 11-24-2009, 09:59 PM
david-b's Avatar
Dave is THAT guy
Re: Ned's 91 GSX
Ya nowadays EGTs are kinda useless. Still good to know what's going on when it comes to heat, but you really don't need one these days. Before WBs, EGTs were basically the way to tune.
75 Monte Carlo
  #41
Old 11-24-2009, 10:16 PM
ned032002's Avatar
Re: Ned's 91 GSX
The reason I asked is because I have a 2 spaces as of right now for gauges. One is being used by the boost/vac gauge and the other is being used by a narrow band AFR gauge. So what I'm going to do is replace the narrow band w/ the wideband gauge, but was considering a EGT but I don't see the reason in spending the money if it's not necessary. I haven't read much about installing the w/b into Link but how involved is that? I'm going to do it but what all needs to be done to install it?
  #42
Old 11-24-2009, 10:50 PM
david-b's Avatar
Dave is THAT guy
Re: Ned's 91 GSX
Nearly all Widebands have an output on the units that you hook up to some logger or device. On MegaSquirt, that output goes to the unit and reads it there. I want to say DSMLink is probably the same way.
75 Monte Carlo
  #43
Old 11-24-2009, 11:14 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Ned's 91 GSX
+1 just run the wideband, forget EGT.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
  #44
Old 11-25-2009, 06:52 AM
ned032002's Avatar
Re: Ned's 91 GSX
I mean when it comes to wiring it in, is it difficult to tap into the ecu wiring?
  #45
Old 11-25-2009, 07:22 AM
ned032002's Avatar
Re: Ned's 91 GSX
Here's another dummy question, ebay oil catch cans? any thoughts?
Closed Thread
