Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-30-2008, 04:22 PM
91talondsm 91talondsm is offline
Re: 91 talon tsi no boost after findind heater hose sliced
could there be any electrical thing that could cause no boost like MAS or somthing? cause i put new exhaust housing on,new turbine housing,new cartraige(the middle) nothin only thing not new is the damn trbine wheel (exhaust side)and with that theres no cracks in the blades,no oil,not bent. turbine spins freely no in and out shaft play.
the sound is like a drimmel tool motor wheeeeeen,wheeeeeen on the o2 side and i hit 1 psi now lol.
550cc's,walbro 255fp,stock 14b at 15psi,palm m130 with mmcd logging software,2 1/2in. down pipe to 3in. exhaust, high flow cat.,2g maf with k&n,custom intake,aftermarket boost guage,mbc,6 bolt with 160 compression. in closet:b16ge3 turbo,rochester 680cc inj.
wish list:wideband,headers,1000cc,e85 conversion,dsm link or map,fmic,20g,272 cams,arp head studs,2600 clutch,lsd,keydriver,. 13sec. daily driver goals.
Old 04-30-2008, 05:30 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
are you SURE your wastegate is closing?? nothing electrical... its not possible...
Old 04-30-2008, 10:42 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
definatly a boost leak. I second the advice to check the wastegate
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-07-2008, 05:29 PM
well it wasnt a boost leak, it was the only thing i didnt replace i think the turbine wheel.anyway i bot a used 14b for 50 bucks lil up and down shaft play no in and out but the exhaust housing was all cracked up,had so many cracks going threw the flapper so i swapped it out with the exhaust housing on the 16g.
Im boosting open waitsgate right now (no line connected) and getting 15 to 16psi max is that norm. for a 14b? or is it boost leak time now.
