Old 06-28-2007, 08:54 PM
snicker64 snicker64 is offline
Re: 2001 Intrigue 3.5 engine
I haven't gotten a chance to try start the the car with the vacuum line disconnected from the FPR yet. Didn't get back out to my daughter's yet. The spark plugs were what was black and very wet with fuel. We just put the plugs in the car. They were A.C. delco plugs the same number that came out of the car. I saw the relay that you were talking about. Thank i will let you know what happens.
Old 06-29-2007, 10:29 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Have your daughter looks at the pics posted in this thread and have her pull the vacuum line. Itd be easy for her. She might even learn somethin, plus it would save you a trip out there.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-29-2007, 10:49 AM
I had a new FPR ordered and it just came in. I'll try and get it put on sometime today. It is made by Standard and the part number is PR223.
Old 06-29-2007, 11:56 PM
samova2133 samova2133 is offline
The SHOP MANUAL on the 1998 Intrigue with 3.8 engine says that the fuel pressure should be 48 to 55 psi. I assume the 3.5 engine would be the same.
Old 07-22-2007, 04:11 PM
Found out what the problem was with the car. It had some ground wires loose,and had the fire shout off. Thanks for all the help fellows.
P.S. tha mass air flow sensor was out too.
What would be a good obd 2 code scanner to buy?
Old 07-25-2007, 08:03 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
I have the Actron CP945. It was around $200 when I bought it a couple of years ago.
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
