Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-07-2007, 01:35 AM   #31
gthompson97
gthompson97's Avatar
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Will not start, no signal to injectors
How exactly did you "check continuity?" There's a resistance test that you can do on each injector, but I highly doubt that all 4 of them went out at once.
95 Talon TSI AWD
97 Eclipse GST
gthompson97 is offline   Reply With Quote
Old 02-07-2007, 07:13 PM   #32
the1cov
I disconected the negative wire on the battery. Then diconnected the the ECU. Then hooked a voltimeter on continnuity to wire 51, "ecu harness injector wire 1." And hooked the other end up to the 1 injector and got continnuity. But also got continnuity to the other 3 injectors as well. And got the same affect from the other 3 injector wires.
The resistance on the injectors is 2.6 they are fine.
the1cov is offline   Reply With Quote
Old 02-07-2007, 07:46 PM   #33
gthompson97
I know you said you checked power with a noid light, but see if you can pull anything from a test light. Check the harness all the way from the injector back to the ECU and same back to the control relay.
We'll get down to the bottom of this eventually.
95 Talon TSI AWD
97 Eclipse GST
Old 02-07-2007, 08:41 PM   #34
the1cov
That is basically what I did. I did a continnuity check, from the injector's to the ecu harness. I will go ahead and do the same to the control relay.
What do you mean by uesing a test light.
Old 02-07-2007, 09:28 PM   #35
gthompson97
Nevermind about the test light. I was sitting in class typing and the teacher walked by so I hadda quickly write something and post it.
Are you sure you did the noid light correctly? This doesn't make any sense. So basically what I'm getting out of this is that there's continuity through the injectors, resistance is fine, but they just aren't opening. Let me think on it for awhile.
95 Talon TSI AWD
97 Eclipse GST
Old 02-07-2007, 10:18 PM   #36
the1cov
I did it correctly, Before I replaced the head I did the same check on the injectors thinking that was the problem. But of course it wan't the noid light worked. Noid lights are not hard to use.
But I just did a continuty check on the relay. And the out come was, 4-5 got continuty to the negative of injectors. and 10 to the + for a split seccond. With key turned on 10, and 3 got continuity for a split seccond.
Old 02-07-2007, 11:46 PM   #37
gthompson97
I agree, noid lights are a breeze to use, but you never know these days, so I just had to ask.
So what you're stating is that 10 & 3 only have continuity for a split second, but all the grounds sides for the injectors checked out fine?
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 11:51 AM   #38
the1cov
Yes exactly what is going on, seems like a fuse or something is getting tripped. But I can recheck 2 secconds latter, and get the same outcome, over and over again.
Old 02-08-2007, 03:35 PM   #39
gthompson97
If it's only holding power for a split second, then the relay must be bad. Check around and see if you can find a cheap one that you know works to check and see if that's the problem. It should be if its only holding power for a second.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 06:07 PM   #40
the1cov
No I checked at the harness with the relay disconnected. And I checked for continuity not for power. I am having a feeling the wires are burnt up somewere, or their is something fried somewere.
Old 02-08-2007, 06:43 PM   #41
gthompson97
I'm soooo confused right now....
I could see partial continuity on 3 because it's hooked to a fusible link (have you checked that)? But partial continuity on 10 doesn't mak any sense, unless its somehow tied into an ignition switch relay/fuse.
95 Talon TSI AWD
97 Eclipse GST
