Old 08-22-2006, 06:25 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Bandits back and still in need
Originally Posted by 79Bandit
......but if you guys got a block in hand (68-76) 400 with a hp rating of 300 up let me know...ill take it.
I bet you would !
And I dont blame you
1999 Grand Am SS 3.4 OHV
Old 08-22-2006, 08:01 PM
heidi ho heidi ho is offline
any book you get should give you a lot of info on what to do, things like checking ring gap, and how to grind them. be carefull connecting the rods to the crank, to be safe, cut some peices of rubber hose to slide over the threads on the rods, otherwise you could nick the crank journals and mess up the bearings, and the crank. get some plastigage and check all the bearings to make sure there isnt too much play between them and the crank. checking and measuring everything and keeping all your stuff clean is the trick. check end play on the rods and on the crank, use the right lube for the bearings, follow all torqe sequences, and double check everything, again make sure you do it with clean hands and parts, and youll be alright. good luck to you, Im in the middle of doing the same thing with my t/a. take your time
oof
Old 08-23-2006, 12:37 AM
79Bandit's Avatar
79Bandit 79Bandit is offline
Minor Set Back....
Welp guys i started the assembly today...when i find out...summit sent me the wrong cam and head assembly... so now i will get the right parts by the end of the week IF they can drop ship it if not it will take 2 to 3 weeks.....dissapointed i decided well then lets start putting the crank in...when i come to relize i ordered the wrong crank....but maybe to my advantage...the one i got is a stroker crank its stroke is a 4.25 (stock stroke is a 4.00) with the stroker crank and my bore that puts my block at a 459 Ci so here is my question...will the pistons i have still work or do you have to get special ones? im sure the connecting rods need to be diffrent...i hope thats it (i needed new connecting rods anywho)...hope you guys can help me out thanks.
Old 08-24-2006, 07:17 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
My guess is that they will not work. With just going with what you have I can't say. You'll have to test fit it to see what the deck height is so to make sure the piston doesn't bottom out up in the cyl. head.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 08-24-2006, 10:28 AM
gmack221's Avatar
gmack221 gmack221 is offline
Most people bulding a stroker motor will put clay on the top of piston, put the motor together but not torque down the head (make sure you have your head gasket in there), then rotate the motor by hand twice around, stop if you hit something solid, but see what the clay looks like, it will show you how much valve clearance you have between piston & valves (remember to leave some extra room for the head gasket getting compressed when torqued down). yes at top dead center you can see if the piston comes above the deck level w/out the heads being on there, but also check valve clearance! Im sure someone who builds strokers can tell you what you need.
Old 08-24-2006, 12:37 PM
79Bandit's Avatar
yea i figured out what im going to do...i ordered some new forged rods (stock size) and called custom ross pistons they said stock rods will do it that the pistons they CUSTOM make (because know one makes a piston for the size i need) will cost me 767 buckaroos....no biggie at this point im taking my to make sure i get the best out of my setup looking into getting some of those edlebrock aluminum heads. soo ill probally dissapear for awhile again and ill be back when i get up and running ta ta
