Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-07-2006, 11:51 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: fuel pumps?
HAve you done a boost leak test? That sounds like your problem. As far as the reving, mine does the same thing so I wouldnt be worried
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-08-2006, 12:36 AM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Re: fuel pumps?
That would have been the last thing I would of thought of. you could be right. Also I think I have a vacuum leak, i can hear air coming from on top of the intake manifold where the two solenoids are. I tried using soap and water but no luck. On my autometer boost gauge reads 16-20 psi on vac.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 05-08-2006, 03:22 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: fuel pumps?
so stock fuel pump pressure is 36psi with the vac installed right? ...just making sure...
Old 05-08-2006, 10:48 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: fuel pumps?
Depends on what your vacuum is. Just do the math. Base pressure minus half of your measured vacuum. Everyones vac will be a little different dependant on mods, mileage, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-09-2006, 08:41 PM
Black99GST's Avatar
Re: fuel pumps?
i can take the vac off my boost gauge right? it reads boost and vac... so vac@ ideal... then set my Fuel pressure to the base of 43.5 and subtract half my vac pressure from the base fuel pressure? and set it to that? right? *its so simple, yet so difficult... i would be so conserned if gas didnt....well... blow up...*
Old 05-09-2006, 10:38 PM
AF - Advisor
Re: fuel pumps?
You shouldnt have to "set" the pressure with the hose on. It should go there automatically, after you set it to 43 with the hose off Otherwise everything else you said seems to be correct.
Kevin Jewer
Old 05-14-2006, 04:27 PM
Re: fuel pumps?
I just put in a new Walbro 190 fuel pump yesterday. The car runs better at idle and all around. I can acutally hear the pump working, it sounds like a turbo supra boosting 30psi at full boost. LOL
1997 Eclipse GS-T
Old 05-14-2006, 07:29 PM
Re: fuel pumps?
I was just thinknig, would a rewire burn up the fuel pump? Even though I have a walbro 190 pump, I just dont want the pump to get screwed because of the rewire.
1997 Eclipse GS-T
Old 05-14-2006, 08:32 PM
AF - Advisor
Re: fuel pumps?
You are not really adding any more voltage to the pump, just allowing it to get what it was designed to recieve.
Kevin Jewer
Old 05-14-2006, 09:25 PM
Re: fuel pumps?
thanks
1997 Eclipse GS-T
