View Poll Results: Does your car idle like it should?
Yes. 21 47.73%
Fak no. 23 52.27%
Voters: 44. You may not vote on this poll
Old 03-11-2006, 11:55 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Does your car idle like it should?
Well I know that it used to run rich....and lean if I let it run down off throttle in gear. So I replaced the MAP to one from an integra and now my a/f (I know they are fickle) shows it being right on...Ill try those all tomorrow maybe, just got home from a concert...Im dead ass tired.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-13-2006, 04:07 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Originally Posted by SiZ
Ohh.... Teh R??
nope...and it should cause you to more than the my current set-up
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-15-2006, 12:30 PM
big tex84's Avatar
big tex84 big tex84 is offline
I think my tps is screwed up, mine bounce after it gets hot. it revs to about 800, then dropps back down to like 700 every 5 seconds or so
Old 03-15-2006, 02:34 PM
FrodoGT's Avatar
Mine did that, but more extreme...it was the MAP, think it had a vaccum leak at the end of the hose, I started the car, pulled the hose (car died), started it with the hose off and of course it ran like dog crap, at about 200rpm. Shut it off and reconnected and its fine, its done it a couple of times...on the highway too, which causes it to run leaner than ever (and the smell will burn the hair out of your nose). Always works for me, the mysteries of hondas...damn little gremlins in there.
Current project:
Rio Red 91 hatch.
Old 01-05-2010, 01:25 PM
DownToGround DownToGround is offline
to update this poll
the si yes c5
the dx no z6
after it warms up it idles real low, but before its warm it idles high.. runs smooth so i leave it be..
