Go Back   Automotive Forums .com Car Chat > Car Audio
Old 01-21-2006, 12:38 AM   #31
jibbijib
jibbijib's Avatar
Send a message via MSN to jibbijib
Re: Is there any reason to buy a cap?
Whats a big three???
Quoted From:carbuzzard -Tokyo is a very congested city (even after Godzilla has stomped on it how many times)
jibbijib is offline   Reply With Quote
Old 01-21-2006, 01:15 AM   #32
vinnym86
vinnym86's Avatar
Send a message via AIM to vinnym86
big three wires, u replace them with bigger guage ones.
Battery ground to chassis, Battery ground to engine block, Battery positive to alternator.
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
vinnym86 is offline   Reply With Quote
Old 01-21-2006, 01:23 PM   #33
ngsm13
ngsm13's Avatar
Send a message via AIM to ngsm13
Don't replace...ADD ...
Add those three wires to the existing using 1/0 wire .
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
ngsm13 is offline   Reply With Quote
Old 01-21-2006, 11:47 PM   #34
vinnym86
vinnym86's Avatar
replace...add... same thing... ...
Old 01-22-2006, 09:12 PM   #35
stoned_pimp420
Send a message via Yahoo to stoned_pimp420
O.K. FUCK what everyone says I owned a 1990 Buick Century and had over 2k watts of just amp in the trunk until I flipped it and I NEVER destroyed a alternator or battery. When I flipped my BLUick I took the entire system out of it and installed it into a 1988 S10 Blazer and still haven't destroyed the alternator nor the battery, now for the sad part about this is the battery that's in the Blazer is the same one that came out of the Century. So what I have to say is FUCK A CAP AND FUCK A HI CAPACITY ALTERNATOR!!!! IF YOU DON'T LIKE IT guess what TOUGH SHIT!!!!!
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
stoned_pimp420 is offline   Reply With Quote
Old 01-23-2006, 03:25 AM   #36
jibbijib
jibbijib's Avatar
Lol, you lost your wagon too? Lol. Yours went out in a lot more style. than mine. Stupid rear axle had to come off. She's gone to the junkyard almost 6 months ago. How'd you flip yours?
Old 01-23-2006, 07:57 AM   #37
IcESouL
hahahahahahaha
and if your alternator couldn't handle the 2000watts what then?
tough shit you wasted all that money on that system and can't use it GREAT IDEA why didn't i think of that before i started this thread!
how about go buy a hi capacity alternator maybe thats smarter
IcESouL is offline   Reply With Quote
Old 01-23-2006, 08:05 AM   #38
alphalanos
This thread isnt locked yet?
96 EJ6. Future home of boosted B18C1.
alphalanos is offline   Reply With Quote
Old 01-23-2006, 09:40 AM   #39
Jet-Lee
Banned
Jet-Lee's Avatar
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
You ARE aware that different vehicles come with different alternators, right? Some can take it stock, some can't. Please shut the hell up now.
This thread needs locked and forgotten.
Jet-Lee is offline   Reply With Quote
Old 01-23-2006, 12:36 PM   #40
biggbabysweetz1
biggbabysweetz1's Avatar
wow. jet you read my mind there.
there too! you must be related to Ms. cleo er somethin
Suck squeeze
Bang Blow
biggbabysweetz1 is offline   Reply With Quote
Old 01-23-2006, 12:42 PM   #41
vinnym86
vinnym86's Avatar
where's paul?
Old 01-23-2006, 02:34 PM   #42
Jet-Lee
Banned
Jet-Lee's Avatar
great minds blah blah blah, lol.
where's paul?
Old 01-24-2006, 07:41 PM   #43
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
High output alternators typically have lower output than the stock one at idle. You might have to play with pulley sizes to work it out. If youhave less than like 1200 watts RMS amp power, you shouldn't really even consider doing an alternator upgrade unless you're headlights are doing the disco blinking. Caps can help stabilize the voltage when listening to music, they don't do much when playing bass tones.
PaulD is offline   Reply With Quote
Old 03-29-2009, 12:41 PM   #44
sparky3489
The thing is, people get confused in the real purpose of a cap. It is not used to cure or prevent dimming lights nor will it change the way the system sounds (both are misconceptions).
To undertsand the purpose you need to understand how they work.
A cap does it's best to keep the voltage at a certain level, but if the voltage changes so will the cap voltage. The cap just makes the change smoother. The dimming light syndrome isn't a voltage issue but rather a current (amperage) drop. The voltage simply follows what the current does. A cap cannot help this situation at all. A cap doesn't provide more power nor does it try to correct it.
Though a cap is perfect for a noisy voltage line. This is why caps are used in AC to DC power supplies as they are used to smooth out the DC ripple for a more smooth DC output.
The ONLY cure for dimming lights is a more hefty amperage source, the alternator.
The REAL powerplant of the car is the alternator. The ONLY purpose of the battery is to start the car and run the accessories with the engine off, nothing else.
Oh, and by the way, the amp has all the capacitance it needs built in...
If your total system power is 1200 watts RMS or more, you will need to:
1. Upgrade the "Big 3" - that is to replace (or add to) the power wire between the battery and alternator, the ground from the battery to the chassis and the ground strap from the engine/tranny to the chassis.
2. Upgrade to a yellow top battery
3. Upgrade the alternator to a high output alternator
Failure to do this will result in the early death of the alternator as it will eventually fail.
Here is a guide that will calculate what size alternator and power wires you need http://www.box.net/shared/uchv4dbk88
You will need Microsoft Excel. If you don't have Excel, use this link http://www.box.net/shared/nkkw1dhk4g
A second (or multiple) battery is never a good idea as it's an added strain on the alternator to charge two batteries AND supply power for the car. The ONLY time a second battery is useful is if the audio system is to be used with the car off or you have a very high powered system.
The alternator must have at least 20% more amperage power than the entire vehicle and sound system combined for a cap to be of benefit which is ironically the same requirements for an amp to be efficient.
A.A.S. degree in Electronics/Industrial Electronics with 25 years in the mobile audio/consumer electronics field, Peavey Media-Matrix certified audio engineer
sparky3489 is offline   Reply With Quote
Old 03-29-2009, 07:51 PM   #45
PaulD
Audio Guy
wow, the last post before yours was mine ..... over 3 years ago ! Most of the people that posted in this thread have either been banned or moved along.
