#31
Re: Re: smog pump super charger?
There are a few things in life I've learned, although I have never given (nor had the desire to give) a doctoral dissertation. The most important thing is that it's not always necessary to know how or why something works, but just to be grateful that it does. Antifreeze is one of those things - I dump it in the radiator, add water, and presto. It works. Three or so years later, repeat above process. Don't drink it, don't put it in Fluffys water bowl, and the world is a good place to be. Can't we go back to discussing bottle rockets, 5 gallon buckets for seats and electric radiator fan turbochargers? |
#32
Re: Re: Re: smog pump super charger?
1. Maximum Torque occurs at a 13.2:1 Air Fuel Ratio. 2. Transitional Fueling and Maximum Boost Air Fuel Ratios are about 12.5:1. 3. Water Injection is most efficient with a 50/50 water alcohol mixture. 4. Methanol, as an additive, is not a practical choice as it is prone to pre-ignition, is not safe to handle and is not readily available. 5. Denatured (ethanol) alcohol, typically 95%, is cheap and is available in paint, hardware, and Home Depot type stores in gallon containers for about $10.00. Isopropyl alcohol can be used but it is often 30% or more water by content. 6. Water Injection allows ignition timing to be more aggressive or closer to stock. In other words boost does not automatically mean retard your timing. 7. Excessive amounts of ignition retard will cause a loss of power and overheating. 8. Water to Fuel ratios should be based on weight and not volume. 9 . Water weighs 8.33 lb per gallon. 10. Alcohol weighs 6.63 lb per gallon. 11. Air weighs .080645 lb per cubic foot. It takes about 150 cubic feet of air per 100 horsepower. It takes about 12 lb of air per 100 horsepower. 12. Water or Water / Alcohol to Fuel Ratios are between 12.5% to 25%. This means Air to Fluid Ratios are between 11.1:1 and 10.0:1 with water injection. 13. Maximum water delivery should be in higher load low to mid rpm ranges tapering somewhat at peak rpms where load is less. 14. Atomization of the water mixture is directly related to it effectiveness. Finer droplets cool the inlet charge better and with less mass they navigate the inlet plenum easier for more equal water distribution. 15. Don’t flow water through an intercooler. 16. Atomized water, just like fuel , does not like to make turns thus making accurate distribution something to think about. This is why port fuel injection is the norm. Water is a fluid just like your fuel. Multiple nozzes, equally spaced in the plenum, although it complicates things, is a superior design. 17. The introduction of water will allow higher boost pressures to be run without detonation. Higher pressures will increase torque. It’s always about torque. 18. Racing high octane gasoline should be used for all forms of competition and for higher than normal boost levels. Water injection as well as charge cooling should be used with racing gas. 91/92 Octane pump gas simply will not cut it. 19. Fuel Injectors operate in the 1 Millisecond range and are not capable of long term usage for H20 as they will corrode or rust shut in a very short period of time. Unless a solenoid can open as fast as a fuel injector it should not be used to "pulse" water injection events. 20. Varying voltage to water injection pumps or using similar schemes is a recipe for disaster. You have to eliminate the variables, not increase them. 21. Fuel Injection pumps cannot be used for water injection. Water is conductive. Gasoline is not. Water will corrode an efi pump shut in a very short period of time. 22. Water injection has a cooling effect on the engine head, valves, and cylinder. Exhaust temperatures (EGT) are largely unaffected at recommended water / fuel ratios. 23. The cooling of potential hot spots in the combustion chamber defeats pre-ignition, the most destructive form of uncontrolled or unplanned combustion. 24. Higher static compression ratios will require a higher percentage of water or water / alcohol. 25. No, water does not burn. We are not combusting the hydrogen in the H2O. 26. At around 13.2:1 or fuel air ratios of .75, EGT’s will peak. 27. Ferrari suspended water in their fuel during their 1980’s Formula1 period. We don’t recommend that you try this...although Acetone will mix with water. This site is outdated, but it has some ratio info, too. http://www.motherearthnews.com/libra...ction_Wizardry |
#35
thank you for getting back on track. i'll have to get the parts and let you know how it goes. i'm guessing i can just tap into the vac tube on the back of the intake. i'm already running syn oil so it shouldn't be a problem.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system. 71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out. 90 cav, 2.2 tbi, gas getter. 99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed. |
#36
hooked it up and gas mileage went from 14 city to 16-17 city. don't know what highway would be but i was getting 25 mpg highway.
#38
Re: Re: Re: Re: Re: smog pump super charger?
The reason they say NOT to allow animals and suggest that humans do not drink it is because when the ethylene glycol reaches the kidneys, they start to break it down into ketones and further reacting to produce aldehydes. They only way to save someones life that has consumed an apprecialble amount of Et glycol is to administer near toxic amounts of ethanol. The reason this helps is because the ethanol in higher relative abundance to the Et glycol will be broken down instead, allowing it to leave the body in the urine before being turned into aldehydes. |
