#31
Re: 2.8L to 305 swap??
ok, i pretty much have mt 2.8L out, does anyone know if the driveshaft is the same length as a the v8? It should be because the tranny crossmember must be the same. Just trying to find all the potential problems before hand.
Chris ![]() ![]() Bad pics of my car without my chrome rims. |
#32
Re: Re: 2.8L to 305 swap??
The 305 has the turbo350 with it, so it would be easier to put the whole thing in, i was just wondering if the shaft was the same length. The tranny in it has a removable end piece where the shaft goes in and where the torque arm bolts up. Does the turbo 350 have the same set up? I don't have the engine home yet, or i would measure and check everything myself.
#34
so my best bet would be to use the 7004r if at all possible, and then the shaft and torque arm will work out. But if not i need the adapter, which from the looksof the one on ebay wouldn't take much to make using the old one.
#36
You will need the harness/electronics to run the tranny, I think they're $100+ haven't checked Ebay and i'm not sure how you would run the harness to the tranny through the ECU after a swap, sure it's possible though, but ultimately will save the rear end problems and give you O.D. |
#37
how much electronics can a carbrated 305 have? Just the sensor isn't it?. My cars not fuel injected, so it shouldn't be that much of a problem
#38
I'm going for whatever is easiest and cheapest. I have both trannys sio i just need the pros and cons of each and what i'll need to use each.
#40
Your not gonna make much power if you leave the motor alone so done worry about that. If the 700 has been rebuilt not to long ago and the th350 has just been sitting around then i would go with the 700. With the th350 you have a little bit better acceloration but worse gas mileage. Like someone said not to long ago, the 700r4 is a great transmission. I have heard bad things about earlier versions of that tranny but maybe with the rebuild whatever problems it might of had from the factory have been eliminated.
#41
I'm getting a cam and headers for the 305 brfore it goes in and then more as i go along. Does anyone have a link where i can buy a torque arm adaptor? I can't seem to find one. Or does anyone have one for sale? Or a driveshaft from an 80-81?
#42
I just bought the driveshaft from the 81 my 305 came out of for $20. I sat it beside the one out of my 84 and it looks to be almost 6" longer. Maybe less. Will this work with the th350 when i put it in? is it the same length to the rear end as the 81 was?
