#31
Re: Re: Re: Re: Re: Looking for educated advice.
Right now my car's a pinch of a work in progress, the body is off the frame as it had some rust and I wanted to put in a roll cage without being restricted by gravity and such for the welding I'm waiting on the heads right now, but I have the shortblock at my shop on my acreage. I don't have a digital camera, or even a camera period right now, but I'll try and scrounge something up when I go out there saturday/sunday.I swear though, half the fun of cars for me is the building of them. I have so many friends that get stressed whenever they work on cars, but for me it's relaxing. My wife isn't into the fabrication bit, but she does things like wiring, upholstry, sanding and other body work, and installing general stuff like suspension parts, etc, so I guess it's more fun when you have a loved one to help you, rather than cussing by yourself or having your wife cuss at you in a dark garage
#32
Re: Re: Re: Re: Re: Re: Looking for educated advice.
1969 Cougar 357w & TKO - 475hp |
#33
OK, talked to my machine shop yesterday. They told me that if I'm going with a supercharger that my stock crank may not work. He said that depending how thick the belt was I may need a crank with a double keyway or somethin and a longer snout. Also he said if the supercharger was pulling hard at all on the snout then my cast crank would not hold up. Do I really need a steel crank? If so I might as well stroke it right?
Do I need to go 8 rib or will 6 rib do? Will 6-8 rib make a difference on my crankshaft situation? 10-12psi should suffice correct?
#34
What year crank is it? If its an 89 crank, I would agree.
You need an 8
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
#35
Do I need a crank with a different snout for an 8 rib?
Anyone know?
1969 Cougar 357w & TKO - 475hp Last edited by 351wStang; 03-27-2005 at 06:16 PM. |
#36
So running this S-Trim at 10-12 psi on my 351 on pump gas (93 octane) how much compression do I need? 9:1? Also will DSS Pro-Lite pistons and rods with a Eagle 4340 crank hold up or are there other suggestions? My machine shop is suggestion Mahle pistons and I think Crower rods and crank.
#37
I would run 9:1. Mine is set up with 8.5:1, but I did not build it.
Email the guys at AD, they have put together 100s of engine packages, they know what works. You can go to the Corral, and search for Eagle, he works there, and knows his stuff big time.
#38
Also I was wondering if superchargers where kinda like turbos are about a chambered muffler. Also would I be better off with shortys or LT headers? Another carb question, are those CSU carbs really that superior for their $750 price tag or would a 750cfm Mighty Demon blower carb for about $550 work just as well? Of course they would both have to be tunned.
#39
After reading up on the turbo pages, those guys swear by the CSU carbs. Its not only the carb, but the tech support you get with it. Think of it also as getting a very knowledgable dyno tunner with the price of the carb, since you can call them, and they will help you dial it in.
AD these guys. www.adperformance.com. I hate chambered mufflers, I would only use a straight through disigned muffler myself. When possible I would use LTs.
#40
i didnt feel like reading all 3 pages so i'm not sure if anyone mentioned it but if you're gonna blow a 351w you're gonna need a little more than a c4 adn an 8.8 rear, either a tremec tko or 6-speed and a ford 9in rear would be my suggestion
#41
a c6 would prolly take it too
#42
I am gowever considering a manual tranny. Just having a hard time finding one that is rated for over 500 hp/tq.
#43
Ive heard that you dont need a real steep gear with boost. is 3.73 too much or should i go down to 3.55's?
#44
For a hydraulic roller 351 I would run 3.08's or 3.27's with boost, 3.55's will be OK, you don't need a lot of gear at all. |
#45
