Old 01-30-2005, 02:45 AM
KatWoman KatWoman is offline
Re: If you were only allowed to have ONE modification on your car, what would it be??
For me, the most important mod would be to upgrade from the stock stereo system. I tried the speed/performance thing, but it cost too much free time under the hood.
Old 01-30-2005, 03:01 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Yay! Me and Kat with new systems
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 01-30-2005, 10:53 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Re: If you were only allowed to have ONE modification on your car, what would it be??
YOU'RE ALIVE!
Old 01-30-2005, 11:21 AM
freakray freakray is offline
AF Modelrater
Re: Re: Re: If you were only allowed to have ONE modification on your car, what would it be??
Originally Posted by SiGNAL748
I suppose you can argue that, but it depends on the way you look at it. Of course, I buy a set of tires, but they're 4 of the same exact thing; While suspension consists of various different items such as shocks/struts, springs, tie bars, braces, etc..
Fair enough point about the suspension, but it also depends on what your starting point is
If you're starting with a WRX, you already have decent suspension, so adding a set of coilovers wouldn't require a major component overhaul.
But hey, if suspension is out, then so should a sound system be, since you can't just buy a head unit
AF User Guidelines
Old 01-30-2005, 11:23 AM
SiGNAL748's Avatar
Tires for all
Old 01-30-2005, 11:38 AM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
Car alarm, if that counts. Always watch your ass. If they rob your ride, you can’t mod your ride anymore.
Old 01-30-2005, 01:15 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
A hood mounted rocket launcher with a laser guided heads up launch system inside my car.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-30-2005, 02:34 PM
GritMaster GritMaster is offline
NAWWWWWWWWWWWWSSSSSSSSSSSSSSSSSSSSSSSSSSS
(Rims)
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 01-30-2005, 07:22 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Stereo
MAKE ART, NOT WAR
Old 01-30-2005, 07:38 PM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
a sub-para e249 machine gun mounted on top of the roof. That why it doesn't matter who would win a race, your ass would be dead.
Old 01-30-2005, 07:42 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
A hot bikini chick like all the real sports cars have.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 01-30-2005, 08:18 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Supercharger or a stroker kit for the Ram.
Pictures of the Truck
Old 01-30-2005, 08:57 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Heh, if i cant get my blower, then I'm with the Thunderbird guy..
werd
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 01-30-2005, 10:10 PM
george536's Avatar
george536 george536 is offline
Bigger TURBO!!!
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-31-2005, 01:47 AM
MadMac56's Avatar
MadMac56 MadMac56 is offline
If I can't have a new motor, then I guess headers...
It's difficult to soar with eagles...When you're surrounded by turkeys!
