Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-31-2004, 03:43 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: need help installing a mbc on my 2g t25
Oh shit, you have a DSM at 17? Can't install a MBC? Well, I have 2 turbo DSMs faster than yours. Jake has 4 or 5 including the 420A which is faster than yours. LOL
Old 12-31-2004, 03:51 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
aggh shit now im having some problems. The car is idling real high at exactly 1250 rpms. Also, there is a lot of lag which i think may have to do with the high idle. The boost is set fine at 15 though. I installed it exaclty as the picture is shown on the top of Jakes post (the first picture). I put a cap on the turbo compressor, ran one hose going to BOV (bottom nipple on mbc) and one hose going to WGA (side nipple on mbc). Do you think it might have do with the hose or the tee? Please help!!
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 12-31-2004, 11:27 PM
Nevermind. I forgot to plug in the MAF. Im such a dumbass.
My Car
Old 01-01-2005, 07:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
haha sweet! I do that all time too, we're both dumbasses
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-01-2005, 07:34 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
not to take it off subject but ,i just got done with my new installs (Dejon tool UICPs , greddy type s BOV) and my car runs the same venting or recirculating , verturally no differance...in the past i read all the posts about how bad venting is with a stock MAF, guess i was under the impression that my car would run terrible when it actually runs quite well...wierd...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-01-2005, 07:37 PM
AF - Advisor
On some cars it will run well in general, but there will be times when you regret. For example, take an on ramp fast using enough maintenance throttle to just stay on the verge of boost. It can get ugly Its these odd times that things go to hell, no matter how well I got my car to run well with all of the contraptions I came up with. And its usually the times when you can least afford an upset car/motor/balance.
Kevin Jewer
Old 01-01-2005, 07:43 PM
97_3clipse's Avatar
so i should just leave the recircualting tube on ,just so its one less thing to go wrong...i think ill leave it on...
Old 01-01-2005, 08:37 PM
AF - Advisor
Its a matter of personal taste, tolerance for these odd behaviors, and how the car is used. I ran vented for years, like I said. I just learned to deal with or drive around the issues it had. But I also spent a lot of time and energy coming up with systems that would allow the car to run pretty well. But when I went to the MAFT, it was like a while different car. I had become used to the way it ran, and then when it really ran well, the way it is supposed to, it was a bit of a shock. But its up to you. You can go back to stock any time as long as the BOV has provisions to.
Kevin Jewer
Old 01-03-2005, 03:26 AM
Re: Re: need help installing a mbc on my 2g t25
I would leave it on man. I mean there really is no performace advantage anyway, right?
My Car
