| Engine intakes, exhaust, turbos, nitrous. |
#31
That is in a B14, the radiator mount is a little different than our cars, *however* the distance from the radiator to block and fans to block is the same.
As you can see you have to trim away a small piece of the fans. A better option is get some Flex-a-lite slim fans.. there will be more room in there and better cooling.... |
#32
A T3/T4 will run about $800 or 850 (Turbonetics anyhow) for the BB center you'll have to pay another $500 or $600. I think its definately worth it if you can spring for it. Combine that with some extrude honing and you'll easily lower your lag by 1000~1300rpms... |
#33
It all comes down to whether you want to afford it or not. What do you think? Sounds to me you might be a little more interested in how the thing looks. So don't get it and save the extra 1k for some nice polished aluminum piping and a dress up kit with braded steal lines and stuff. It also depends on what turbo you want to get. On a T25/28 it might not be as noticable, or necessary, as on a T3/04E with a .82 A/R turbine which will take longer to spool. But then again you wanted Brian to answer soooo.... |
#34
B-Boogie
Do you happen to have that site for the slim fans? I know that that would be a better option for me, and p11gt too.... Also, i know you've already made me two lists and your probably gettin tired of writing them out for me, but could you possibly give me a final list of what i need in detail to make my 300-320whp, if you want you can e-mail me it?? ![]() You've been a great deal of help b-boogie, thanx alot for the help and info mang, i apprea. alot. B-BOOGIE IS DA BOMB
DBK Team VISION -Viewed as a way of life- Total Performance Racing!!! Mad Props to all the G's Out There!!! Deal with the difficult while it is yet easy, Deal with the great while it is yet small.... |
#35
Ball bearing....optional...If I were you..don't get them...waste of money...if you are into racing and have endless amount of money or worried about boosting 500rpm faster then why not go for the ball bearing....
#36
, G-FORCES!!!!!!!:frog:
G20 KR4 Sport ----------------- Tinted (20%); Momo Cobra Shift Knob w/ Boot; RAZO Titanium Stainless Alloy Pedals; PIAA Super White Bulbs (#15660); PIAA Platinium Super White Clearance Bulbs (#19169); PIAA Ion Crystal Bulbs (#13555); Clear Repeaters; "Primera" badge; "GT" badge; Q45 Infiniti emblem; Red G2 Brake Calipers Paint. |
#37
BTW it's former Vancouverian, turned to Torontonian and back to Vancouverian.
#38
I guess I should write up some sort of turbo faq. I'll add it to the to-do list. ![]() Anyhow... the list I posted in the first page will get you where you want to go. The only thing I think is missing is ignition, gauges, fans/radiator if you want to upgrade those too.. You can get the Flex-a-lite Slim fans at www.summitracing.com ...model number is 210. http://store.summitracing.com/produc...earchtype=ecat BTW.. they are also offered in blue, red, or yellow plastic housing if you're interested.. although Summit only stocks the black ones. |
#39
Hey Boogie
![]() With that whole set up from that list will i need to lower my compression? Will a head gasket help, or would i need to get the rods and pistons, or will the stock manage at 9:3:1? -i think thats the comp.-
#40
G20TurboVisionCrew , after your done, gimme a ride
and b00gie , did u ever figure out the ecu wiring for 2000+ p11s? |
#41
put it in the FAQ section.
#42
9.5:1 compression ratio should be fine if, like Aznvirus said, you do it properly. You can boost about 10psi on a decent turbo/FMIC and up to 13-14psi with water injection on a 9.5:1 stock motor. After that you need to start working on upgrading the ignition. |
#44
#45
UK's 1st Turbo'd Primera GT Please visit my site www.p11-gt.co.uk Updated 7/3/2003 Some Exterior Mods to go now. Vote for my car at www.ridejudge.com user name P11GT ![]() VRRRROOOOOOMMM TIIISSSSSSHHHTT!!! |
