Old 11-21-2004, 01:26 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: Re: Got an LS....
Originally Posted by LadyNRedSi
i need to find a driver's side stock mount for our 93 ls, ASAP car vibrates like a mofo. i know this isn't exactly on topic but it's as close as it's gonna get around here and i wanted to vent
psh
i just parted out a 90 teg GS....
i have the motor in my garage right now. with the mounts. let me know if u want it Ami, gimme an offer
Old 11-21-2004, 08:59 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: Got an LS....
Holy shit what a day! Get ready this is long!
Update, I didn't get any pics. But I did get a lot of headaches! We started working on this thing at like 9am and didn't get done 'till like 6pm. The motor was on the ground at first, took all the axles and stuff outta the other hatch, took mine out, then we forgot you can't use the front mount with the LS. So we were going to bang it outta the way for a bit untill I could cut it off, but then we thought that he's gonna need the mount for his car (that my old mini-me is going in to) so we had to swap the front crossmembers 'cause his was shaved off nicely for the LS. Then we get the motor in, we had problems with the rear mount, took a while but we got it in nice. We went to start hooking up the wire harness etc, and some of the wires were down to like 1 strand and broke out of the connector, so we had to take em apart and recrimp a couple wires etc. Then we got the dizzy on and it had a wire missing just hanging out of the hole it was supposed to be in. Luckily we had an old one there, we just popped that one out and popped in the new one. Then the intake had all these open spots where on the other intake we had, they looked like they were sealed off from the factory. Soooo....????????? Anyway, skipped that-gonna plug em up later or use the other manifold. Then we get down to put the axles in and they dont fit! FUCK! We then had to swap out all the hubs and shit from his hatch, the axles went in, got all that back together. Then we wanted to turn the motor over with the synthetic oil dropped down in the motor to wet the rings a little 'cause the motor has been sitting a while. He hooked up the battery while I was in the car and told me to try to crank it.....nothing. Then I get out and smoke is like comming out of the back of my engine somewhere! So we try to figure out wtf is going on. The line comming out of my NOS solenoid was very hot. Odd. Seems that the nitrous line was hitting the intake manifold and was burning. WTF? THE NITROUS LINE HAS NO POWER!? We disconnected the battery cable and looked some more, found out the starter was shorting out the whole block. We took it advance auto parts and they tested it and it almost burnt the place down lol, it was doing the same thing when it was on my car. So I ordered and new starter and pretty much have to go from there tomorrow. Linkage, radiator, starter, wires, plugs, intake and we should be good for test #2. Lovely
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 11-21-2004, 09:18 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
Re: Got an LS....
sounds like fun, i want an ls hatch so bad. Im jealous
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 11-21-2004, 09:40 PM
quiXilver's Avatar
hatch=: crx=
B18A
Old 11-21-2004, 09:56 PM
Jetts's Avatar
Re: Got an LS....
i know, im just saying i want a hatch
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 11-21-2004, 10:06 PM
!M!}['s Avatar
!M!}[ !M!}[ is offline
Originally Posted by Bakla0stha
Dude i would just do LS all the way
no turbo or nothing, all motor
thats what i have and im spanking b16 like nothing,
no offense to the guys that have one, but where i live thats all there is here, b16 that , b16 this, im sick and tired of freaken b16, yeah tru they make whopping high hp, but look how much you got to spend to get that, thats crazy, and if your mommy and daddy and put down 3gs ona motor, then good for you, with 3gs in an LS, i have hella options, thats y im doin ls all the way
it did not even cost me 3 gs to get my hatch and do the b16 swap with a few mods
Old 11-21-2004, 11:11 PM
quiXilver's Avatar
Re: Got an LS....
i was goin b16, but this deal I couldn't pass this deal up.
i just hope this motor i bought lasts long enough for me to rebuild the other block. i just ordered my jdm b16 pistons, rings, bearings, clutch/8lb aluminum flywheel combo and a good head gasket.
B18A
Old 11-22-2004, 03:54 PM
Bakla0stha Bakla0stha is offline
Send a message via AIM to Bakla0stha Send a message via Yahoo to Bakla0stha
Re: Got an LS....
hey !M!}[
i was wasnt emplying that u need to spend 3gs to fix up a car, it was just an example. it be nice to have 3gs to fix my car
like i said Ls in a CRX well dominate!!!
LS FOR LIFE!!!
Old 11-22-2004, 05:24 PM
quiXilver's Avatar
Re: Got an LS....
Update...
Well we put the new starter on, linkage, radiator etc everything back up and ready. So everything works great except the motor
It actually idles and everything, just there is water mixing with the oil, and it doesn't rev to high. I think it's the head gasket don't you? I've already ordered one so I'm going to replace that and see what happends. Anyone got a link to all the torque specs for the LS head? Thx.
B18A
Old 11-24-2004, 01:18 AM
quiXilver's Avatar
Re: Got an LS....
Update. Took the head off, the gasket didn't seems bad so I'm wondering if he overheated it and warped the head. I'm going to have it checked out.
BTW the motor we took out, we put in that guys hatch, and he's letting me drive it around So now I have a nice lil dark blue hatch with HX's. I'll put some pics up tomorrow for all you hatch lovers =)
Question. Is there anyway to tell if a block is cracked on the inside? Thx ahead of time.
B18A
Old 11-24-2004, 01:38 PM
1PhatCX's Avatar
you might be able to see cracks in the cylinder walls. i'd yank it out again and strip it right down and check it over completely... trust me, its worth it
Old 11-24-2004, 02:22 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Got an LS....
magnaflux the block, take it to a machine shop and see if the block and head are straight.
civicHBsi91, i thought you were a d series man, i remeber you going off about how d series rule and b series suck and all that. haha u cant resist the DOHC side
Team Lonely Drivers
Old 11-24-2004, 06:34 PM
1PhatCX's Avatar
u use that loosly eh? u forgettin bout the ZC? its d series and DOHC
Old 11-24-2004, 07:13 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
Why do you even mention the ZC. Its the most garbage engine ever.
88 civic dx
Old 11-24-2004, 08:53 PM
Re: Got an LS....
yes i use it loosely, because its more of a joke then being serious. i know about the zc and it being dohc, i just dont like that motor so i dont include it.
Team Lonely Drivers
