| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#31
Re: Adding a circuit that is hot during run only
Thanks! I posted a message over at a caddy forum too, so maybe they'll have an idea of where to get the pressure.
Excellent idea on the isolated battery... much like a motohome is set up with a coach battery isolated from the van battery. The thinking caps are ON here. A very big thanks to all who've chipped in on this!
Dragging people kicking and screaming into the enlightenment. |
#32
I like the oil pressure switch idea. Run thru a relay it would probably work better than my old vacuum switch idea. We used them because the are also available with a pot so the output would vary with load. ..... Here comes the boss, gota go.
![]() Yes, I am retarded. |
#33
curtis, are you going to add a override switch to? like on/off/run
#34
That would be a smart idea. That way I can bypass it entirely if I don't need it or force it to come on if necessary.
This project is really going to tax my electrical abilities. I have a 21-circuit aftermarket harness. I'm going to be adding 12v plugs in the rear seat area, and also making the interior lighting be hot, switched with the door, or off.
#35
that doesn't sound to hard at all(at least for me) just post if you need a wiring diagram drawn up or such.
#36
