Old 07-07-2004, 11:47 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: in progress | toyota levin ae86 [lots of pix!]
a suggestion with the masking tape is that you take off the masking tape after 5-8 minutes (when paint seems somewhat dry). If you just leave the tape on until the paint fully cures, the paint might lift with the tape.
Old 07-08-2004, 01:12 AM
sugarfree's Avatar
sugarfree sugarfree is offline
mm.... i leave the tape on for the whole process, ie: mist coats (+/- 4coats), then heavy coats (+/-2). so... if i doing it slow, it'll be on it for 1week. but... if i doing it quick, maybe 3-4days. so... yea, i cant avoid that. but then again, is my method wrong??
however, this is my homemade oven
and.. this is my spray booth.
lastly, this is the pitting im talking about. this is after i scrub it, so, before, it was way worse than this.
life begin after 5,600rpm
BOOBAA rulez
Old 07-08-2004, 03:16 AM
Wow, that's some serious pitting. What type of masking tape did you use? I was informed to remove any masking in two-tone painting while the paint is still tacky not dry, maybe that's the problem.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 07-08-2004, 03:50 AM
youngdrifter_x's Avatar
youngdrifter_x youngdrifter_x is offline
Send a message via AIM to youngdrifter_x Send a message via Yahoo to youngdrifter_x
When I do my 2-tones i usually take it off while its still wet, but be careful..you can ruin it. My theory is that when the paint hardens it turns into one big peice of paint... looks pretty by the way
-Andrew R.
Old 07-08-2004, 04:46 AM
sugarfree's Avatar
honoturtle, im using tamiya's one. im quite surprised of what happened to me.
removing the tape while its partly dry is rather hard for me. cos... most of the time, my masking tapes are not in one piece, meaning, there will be a lot of them that overlapping each other. so, there will be another problem if im trying to remove them while the paint is partly dried.
well, the thing is, learn from the mistake. this is my 1st kit that i used that heat method to cure the paint (cos its winter here, so the air's a bit humid). next time, i'll try not too use heat, but just close the bucket and make it semi-air-tight. therefore no dusts or any loose particles air borne will destroy the paint.
BOOBAA rulez
Old 11-14-2004, 10:35 PM
sugarfree's Avatar
sory guys, slow updates..... but holiday's coming, so i will finish it off, and move on to my next one on the list. hehehe
just bear with me, ill be updating this before the new year.
BOOBAA rulez
Old 11-15-2004, 12:16 AM
El Krammito's Avatar
El Krammito El Krammito is offline
Send a message via MSN to El Krammito
looks cool so far. i need to finish mine it's being "judged" in a month.
The Krammit
Old 11-15-2004, 05:04 PM
Dr.AK's Avatar
Dr.AK Dr.AK is offline
Another one of those Levins popping up here Makes me want to build another Levin
Looks good so far. Even with those painting problems
Old 11-15-2004, 05:38 PM
sugarfree's Avatar
haha... thanx bro. i need to repaint the black bit on the body. i cut-polish the paint job to get rid the bubles... but its ended up with i cut too deep, therefore 'erasing' the paints. so yea... its quite a mission to cover those white coloured area.
holiday's coming up with a fresh dough from my salary. well, not much, but i think its enough for this time. hehehe.
BOOBAA rulez
