| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#31 | |
Re: 98 isuzu trooper buring oil excessively
if you were burning that much oil your Trooper would be smoking like a burning tire.
#32 | |
Trooper excessive oil consumption
All, you might want to check out the following link.
http://www.4x4wire.com/forums/showfl...4&fpart=3&vc=1 |
#33 | |
Re: Trooper excessive oil consumption
A piston travels up and down the cylinder and if there is insufficient spring tension on the compression rings the piston rocks and in severe cases the piston skirt will strike the wall of the cylinder, this is commonly known as piston slap.
Although there can be sufficient spring tension to ensure reasonable compression the rocking motion unfortunately releases oil from the upper ring and that oil is burned in the combustion process, leading to a loss of oil from the sump. This process is generally referred to as excessive oil consumption, because it was not the design intention that the oil would be released into the combustion chamber for burning. At higher revolutions the leakage tends to increase, as does the burning thereof. The 2 stroke engine however, is intended to release oil into the combustion chamber for the purpose of lubricating the moving parts, as it doesn’t have an oil pump to lubricate those components directly, therefore excessive oil consumption would only exist if the oil mixture ratio or oil injection pump were not set correctly and there was too much oil being delivered to the combustion chamber. BTW paragraph 1 is much the same for a bent rod |
#34 | |
This won't fix it, but it may help. First put some Seafoam in your crank and run it for a few hard miles. Then change your oil but throw in a quart of Lucas in place of oil. It increase oil pressure and life in my '90 Trooper. I started burning at 30,000 but made it to 120,000 before I swapped out the 2.8 for a 3.4L.
#35 | |
Isuzu Guy
![]() Join Date: Jan 2004
Recently recieved this email:
Found the "SEA FOAM" info on this site. I had all but given up on the oil consumption problem on my 2000 Trooper 3.5. Dumped a bottle of the product in my crank case. Drove 100 miles and did my usual synthetic oil change with 10W 30. The oil when drained with the SEA FOAM additive looked and had the consistency of black gasoline. Four hundred miles later and the oil level has not dropped. By now I would be down 1/2 Qt. The Trooper runs smoother, quieter, and seems to have more power. I will follow up with more info at the 800 mile mark. I am impressed. Regards, Jethro
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
#36 | |
Glad to hear that things are running better. Did you also add the lucas? I think they make a type especially for synthetic oil. You'll be very happy. I use it in every car I own.
#37 | |
![]() Join Date: Mar 2005
We have a '99 Trooper that used about 1-11/2 quarts between changes(3-3.5k) & I thought that was a lot! Seems my consumption is less than some. I just switched to Mobil1 truck & suv 5w40 because of the additive package it has, it is my oil of choice for my 6.0 Ford diesel also. The first thing I noticed was the noisy lifters quieted down quite a bit. The oil consumption seems to have dropped by about 1/2 quart.
#38 | |
Do they smoke?
One point that has been brought is "if it's burning that much oil it would be smoking like crazy". There was never a comment on this.
Could someone that has high oil consumption confirm or deny this? The reason I ask is because I'm looking to buy a 98 Trooper with 90k miles, I inspected it drove it and I see no apparent problem with it, in fact it seems all great, engine is really clean, air filter is too, I couldn't go as far as inspecting the inside of the carburetor but the seller (private) assured me it uses no oil at all. The idle seems pretty steady and I couldn't get any smoke out of it worm or cold. Also the seller is not the first owner and there is no way for me to know what if anything was ever done to the car, any pointers as to "what to look at/for"? TIA |
#39 | |
![]() Join Date: Feb 2005
My 99 trooper uses about 1qt / 1000K and does not smoke at all. Sometimes when going into overdrive it would put out a little smoke. I've just finished treating with auto-rx and it doesn't seem to smoke any more. I haven't gone lone enough to see if it has stopped using oil. The only problem I've had with the truck was a bad intake manifold gasket at around 50K, and the cluch fan seezed at around 80K. At 98K, I believe my gasket is just now going bad again, appearently a common problem on these trucks. With the design problem on the rings, the only way I could see one of these trucks not consuming oil would be good synthetic oil from the start. In either case not a problem, just watch the oil level. I really like my truck and will try to keep it running well for another 100K.
#40 | |||
Re: Re: 98 isuzu trooper buring oil excessively
#41 | ||
Isuzu Guy
Re: Re: Re: 98 isuzu trooper buring oil excessively
recent post from an owner with 225k. http://www.automotiveforums.com/vbul...d.php?t=375612 I've seen about 50 post over the last year with +98 Isuzu's with over 150k.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd Last edited by amigo-2k; 03-07-2005 at 10:02 PM. |
#42 | ||
#43 | |
interesting article, but I question the results. I started burning oil at 30,000 in my '90 2.8L. Everyone later told me that these engines are junk. Using the Lucas on and off over the next 10 years I believe enabled my engine to hit 120,000 miles and I was hauling over 1/2 ton of cement on a regular basis over for the last 2 years. Without the Lucas i'm sure I wouldn't have been able to get up the hill. Now, for many years, since my trooper burned so much oil, I never changed the oil properly, just keep adding it. So when I pulled the engine, it was fairly gunky inside, but I do not know if it was lack of maintence or the Lucas ( which I doubt ) that caused the problem.
I can say this though. Many people were surprised my engine still ran as well as it did, and I have never seen my oil look like the oil in that article. I put a 3.4 L from a 95 Camero in the Trooper and it was very clean internally. It had 70,000 miles on it. Hopefully in about 10 - 15 years I will rebuild it and let people know how it weathered under proper care and Lucas. Also, I just relaced my wifes escort engine. It has 20,000 miles and I have added Lucas, but I have decided to make the switch to full synthetic at the next oil change. Will be interesting to see if I develop a leak or not, but I have already flushed it with seafoam and do not foresee problems. I would like to switch my Trooper over to synthetic but I am not as confident with a higher milage engine. Maybe I'll stil give it a try. |
#44 | |
1999 Trooper Problems
My 1999 Trooper engined seized up while on vacation last Thanksgiving. After having the car towed to two different dealerships and paying to have the engine broken down (at Isuzu of America's direction), I find I need a new engine. Like many others, I regularly serviced this car and, except for this huge problem, love the car. I can no longer get Isuzu of America speak with me and, in fact, the Supervisor at Owner Relations hung up on me. This engine obviously had design fault and, it seems, that most problems occur after 60k miles and, hence, after warrantly. I want to know if anyone has successfully sued or gotten any satisfaction from Isuzu. There are many of us who have gotten "taken" on these vehicles. I've purchased three Rodeos (2-2001s; 1-2002) and am (was)a good Isuzu customer.
Replacement engines are either expensive, unavailable, or suspect (I've heard that they are not a good engine to rebuild). Any suggestions? Other then the engine, I have a great car (leather,sunroof, cd changer, etc.) in MI and I live in KS. Any one interested in buying the car? |
#45 | ||
![]() Join Date: Apr 2004
Re: 1999 Trooper Problems
What's your asking price for the truck?
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
