Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 12-03-2005, 01:58 AM   #31
2octops
Re: Re: Re: Looking for 03' 4Runner Key Codes
Originally Posted by Ranga
I have a 97 Camry LE and I need the programming instructions. I bought (2) BAB237131-022 REMOTES ,from a local workshop, but there are no instructions. Someone suggested that I try locating the ECU under the seat. There is no ECU under the seat.
Thanks
I have all of the procedures for about every vehicle on the road.
Please send me an e-mail at [email protected] for more info.
2octops is offline   Reply With Quote
Old 12-03-2005, 01:59 AM   #32
2octops
Thanks
The procedure for the ECU under the seat is not the correct one for a 97-99 Camry.
Old 12-04-2005, 04:13 PM   #33
Ranga
Re: Re: Re: Re: Looking for 03' 4Runner Key Codes
Does anyone know what the procedure is? I looked for the purple wire in the mirror switch, but it was not there, I tried the procedures given for the 2002 camry, but they dont work.
Please help.
Thanks,
Ranga.
Ranga is offline   Reply With Quote
Old 12-04-2005, 06:50 PM   #34
Onblsht
Authorized Vendor
Onblsht's Avatar
Re: Program keyless remote-Need instructions
Ranga,
The 97-99 Camry "purple wire" instructions are for the factory GQ43VT7T remote.
If you have the BAB237131-022 remote for the dealer or port installed system, the instructions are different. Are you sure you have the correct remote for the car?
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline   Reply With Quote
Old 12-30-2005, 09:44 AM   #35
bzman
Smile Re: Re: Looking for 03' 4Runner Key Codes
Hey,
I know it's been a while since you offered to post toyota transmitter reprogram codes, but I have a 1997 Avalon and just bought two new transmitters from wireless and the program instructions deal with resetting the security ECM and I have spent 2+ hours tearing apart the dash to no avail. I tried jumping the light warning module in the trunk with no luck. So, if you could post the procedure for my avalon it would be great. Thank you
Originally Posted by FourKix
Hey everyone, I solved my own issue (I like it when I can do that). If anyone needs codes for 95' - 03' Toyota Avalon, Camery, Celica, Corolla, Echo, 4Runner, Highlander, Matrix, Prius, Rav4, Sequoia, Sienna, or Solara I have most of these (they all use 1 of 4 different codes).
I will try and post all 4 codes some time but not tonight. It's late and there is to much info to list. Maybe I will just post info on my personal web site and give you all the link. I have a hard copy at the moment.
If you need remotes, check here: http://cgi6.ebay.com/ebaymotors/ws/e...sort=3&rows=50
I bought mine from this person and it was new and all original Toyota keyless remote at a fraction of the dealer price and worked great! He will also send you programming information.
Take Care Everyone!
bzman is offline   Reply With Quote
Old 10-05-2006, 05:51 AM   #36
Chris P
Re: Program Avalon keyless remote-Need instructions
Hi folks not sure If I am doing this right. First time - anyway I need the programing instructions for the remote entry for my 2000 Avalon. I have read the instructions posted. Only problem is that My car is in Australia and only has one button on the remote labelled "Doors". I am hoping it is an older or different version of something delivered in the US. Failing that if there are any Aussie readers who could help I would be greatful
Chris_P
Chris P is offline   Reply With Quote
Old 03-06-2007, 01:06 PM   #37
nhatkientanh
Originally Posted by C_Haf
Is there a way to de-program a remote. It now works for two 1999 4runners in the area. I tried to remove the battery but that did not de-program the remote. Is that some thing that removing the battery on one of the cars will solve or is it in the remote it self.
In step 8 of JDEL section. You need to switch ignition ON and OFF for 5 times
to erase all registered codes.
nhatkientanh is offline   Reply With Quote
Old 05-20-2007, 05:21 PM   #38
becerrda
Originally Posted by daffy_duck-010
The dealer was happy to give it to me so here is the procedure. let me know if it works. (Camry 02 and 03)
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
4Runner Instructions
I have a 1999 4Runner and I followed the directions above (which I've copied below) with one exception. In step 8 -- I held the lock button instead of the unlock button in order for the directions to work.
Step 1 - open drivers side door and get in your vehicle.
Step 2 - put key completely into ignition,then pull out.
Step 3- with door open, lock and unlock 5 times on door console (ten clicks total).
Step 4 - close door then open door.
Step 5 - lock and unlock 5 times on door console (ten clicks total).
Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times)
Step 7 - now quickly press the lock and unlock buttons at the same time only for about a second.
Step 8 - then quickly press the lock button for just a second.
Step 9 - exit car and close the door
After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle.
I just used this programming on a new (free) remote and it worked. Thanks for posting this so long ago
becerrda is offline   Reply With Quote
Old 05-31-2007, 10:11 PM   #39
HelpSearch
Originally Posted by Brian R.
Here's a confirmatory link for daffy_duck-010's post:
http://www.geocities.com/toyota_spee...ess_entry.html
Hi Brian,
Do you have the page for the 2001 4runner? can you please help?
HelpSearch is offline   Reply With Quote
Old 05-31-2007, 10:46 PM   #40
Onblsht
Authorized Vendor
Onblsht's Avatar
The 2001 4Runner with remote FCC # HYQ1512Y uses the same instructions as the 1999 4Runner in the above post.
Old 05-31-2007, 11:24 PM   #41
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
From the FAQ thread:
http://programyourremote.com/
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 06-01-2007, 10:12 AM   #42
becerrda
Originally Posted by HelpSearch
Hi Brian,
the remote i used came from a total 2004 4runner.
it worked after a couple of attempts. But i clicked on the unlock and lock a total of 12 times.
Old 06-01-2007, 09:51 PM   #43
HelpSearch
Does anyone know the battery type that goes on these remote control. I bought CR2016 which seemed to fit but still did not work. The light was not on when pressed. originalkeyless.com personel told me to use CR2025 but it is too thick to fit. i have tried to reprogram but did not work i think due to the remote control battery issue.
What is the right battery for this remote?
Old 06-06-2007, 10:42 PM   #44
becerrda
opened my remote panasonic cr2016 3v
Old 07-22-2007, 05:36 PM   #45
MWSchafer
Re: Program for keyless remote,2000 Camry
Previous programs for 2000 Camry keyless remote don't work. The following program is the right one.
1. Start with key out of the ignition, driver door is open (all others closed),
and driver door is unlocked.
  • Insert key into the ignition (don’t turn it) and pull it out
  • Perform these steps within 40 seconds:
a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles with lock.
Use an even pace and try to go about one cycle per second. 1 cycle = 1 lock and 1 unlock)
b. Close, then open driver’s door.
a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles starting
with lock.
Use an even pace and try to go about one cycle per second. (1 cycle = 1 lock and 1unlock)
b. Insert the key in the ignition cylinder.
c. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF.
d. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF.
e. Remove the key from the ignition.
  • Within 3 seconds, the power door locks should cycle automatically indicating successful entry
    into programming mode.
    Return to step 1 if the locks do not cycle at this point.
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and
hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful
programming.
If the door locks don’t cycle, or cycle twice, repeat steps a and b-your remote has not
been accepted.
c. Repeat steps a and b in step 6 for each new and existing transmitter.
7. Close driver door.
MWSchafer is offline   Reply With Quote
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 09:13 AM
Dealer says new computer needed to program keyless remote, I think they are wrong.. hoover101 Sequoia 2 03-17-2010 12:17 AM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 01:28 PM
