Old 10-19-2009, 10:38 PM
Davemex1986's Avatar
Davemex1986 Davemex1986 is offline
Re: gtp problems?
the fuel filter is under the drivers side right? or is it in the gas tank?
Old 10-19-2009, 10:42 PM
Re: gtp problems?
nevermind im a dumbhead i found it in that page u told me to go to lol.. thanks
Old 10-19-2009, 10:49 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: gtp problems?
I know PEMEX is all i have to work with !! lol but its cheap lol but yah i know it sucks i said its dirty. since its the only gas station in mexico i have no choice but autozones are a dime a dozen all over the city its no different then the states wal marts , malls, clubs bars no different cept for the difference in class of living rich and poor.
Pemex has a high sulfur content and obviously Mexico has no clean air/emissions standards. Cuidad Juarez right across the border from El Paso has several Autozones but the parts are expensive compared to the U.S. and the stores are not well stocked with the parts you need. Most come across the border to the U.S. as a result and most do not have auto insurance either.
Moot issue anyways. Unless the SES/CEL light is on there will be nothing to scan for. Autozones in the U.S. normally do not run an odb-ii scan unless the SES/CEL light is on. But I guess anything goes in Mexico. You can purchase your own odb-ii scanner to check for DTCs which Autozone sells at least in the U.S.
As suggested check to make sure the boost bypass valve is fully closing at WOT or high acceleration. If that is good then there is probably an internal issue with the Eaton M90 Gen3 supercharger.
Originally Posted by SL3000gt View Post
That post has been moved to the Toyota Tercel forum.
Timeslip 08/12/06
AF Community Guidelines
Old 10-21-2009, 01:39 PM
rkvons's Avatar
rkvons rkvons is offline
Re: gtp problems?
but the half boost thing is that normal till i change pulley?
My 98' always achieves 100% boost when I stomp on it.
Old 10-21-2009, 07:12 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: gtp problems?
Originally Posted by richtazz
Do you get the "check/service engine soon" light on when you turn the key to on but with the engine off? If not, the bulb may be removed or burned out.
0-60 in 10sec? They must be mixing snails & turtles in that Pemex! Have you previously had any CEL's and took the car to a mechanic in Mexico? The shops down there are notorious for disabling the CEL light and not fixing the problem! Anyway, sounds like a clogged cat and some other problems to to me!
Old 10-21-2009, 09:50 PM
Re: gtp problems?
well i looked there is not cat... i bought plugs wires and fuel filter today but i had the autozone guy plug it in to the computer and it gave us the code for no O2 sensor so maybe thats it? i really dont know how that effects the car
Old 10-21-2009, 10:22 PM
Re: gtp problems?
is there two 02 sensors on this car? i can see one behind where the shifter would be under the car there is a weird shaped bend and i would asume there is another before that yah? where the converter would be that i dont have for some reason...
Old 10-22-2009, 06:46 AM
BNaylor's Avatar
Re: gtp problems?
Yes there are two. One pre CAT and one post CAT. Since you do not have a converter installed which is not uncommon in Mexico the rear 02 sensor is irrelevant since it monitors converter efficiency only and any DTC like P0420 it may give off. The front 02 sensor is the one that helps control air/fuel mixture ratio in closed loop mode operation and keeps emissions in check. When you go WOT or pedal to the metal the front 02 sensor is not used since the PCM switches to open loop mode operation so it probably is not your problem.
Post the DTC that was retrieved.
Timeslip 08/12/06
Old 10-24-2009, 03:38 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
Re: gtp problems?
i had this same problem last year! i think it was a bad fuel pump causing all sorts of problems but i dont remember..ill try to find the post about it, or the bill..ill let ya know
Old 10-24-2009, 03:49 PM
TDWPgtp's Avatar
Re: gtp problems?
ok i remembered. there is a plug in front of the boost valve under a wireharness. i dont know what it is or what it does but mine was unplugged for some reason and when i plugged it back in the car started running perfect again.
also if thats not it maybe check for vacuum leaks as im pretty sure they can cause similar problems
Old 10-25-2009, 01:03 AM
Re: gtp problems?
yah i looked there is like 1 line not even hooked up! and the others are cracked iwth tape on them.... damn mexican auto shops ill take a few pics and show you guys what i have i rev the motter and the throttle thing on the supercharger is slower to kick in and dosent move all the way when i rev the motor and i mean come on its 0 to 60 is over 10 seconds! that blows i cant even burnout in the rain!
Old 10-29-2009, 02:58 AM
worktester worktester is offline
Re: gtp problems?
well for starters u definataly have a fuel/spark issue. replace filters and plugs/wires and only premium gas. as far as your boost guage u might have a throttle stop out of adjustment. your boost guage should max even at a stand still. good luck .:banghead :
Old 10-29-2009, 07:07 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: gtp problems?
The Rev limiter limits the RPM's so the boost cant max at just revving. In fact, I have never seen my boost register at all when I revved (although I don't sit there and rev my motor). Also, the 3800's to my knowledge do not have a throttle stop adjustment.
I think he found his problem, a vacuum leak due to shoddy repairs with electrical tape.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
