Old 09-25-2009, 05:52 PM
happydog500 happydog500 is offline
Re: 5 Quarts oil way to much?
Originally Posted by HotZ28 View Post
I think you may have found your answer! '96 Series II engine calls for 4.5 qts with filter; so therefore, the dipstick & tube were designed to show full level with that amount. If I add 4 1/2 qts with filter, it shows the level as full. As previously mentioned, if I add an additional 1/2 qt (which I occasionally do) it will show the same as yours.
It’s no big deal if you add 5-qts, it will not harm anything. It could be that GM finally decided that most people would not add oil until the dipstick is showing a quart low; so in theory, if you are driving @ highway speeds with 3 1/2 qts in the engine, you have 2-qts circulating and only 1-qt in the pan. Now if you are driving @ beyond normal highway speeds, or on curvy roads, 1-qt in the pan could present a problem, hence the additional recommended ½ qt! Logical thinking!
OK, thanks for the input. I don't understand why a 1/2 quart goes up so far? Seems like a lot more then 1/2 Q. This is after I drove also. Waite a little longer and it's even higher.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 09-26-2009, 08:40 AM
Blue Bowtie's Avatar
Registered Offender
... Anyway, here is an enhanced picture of your dip-stick.
There's something I NEVER expected to read in this forum.
Old 09-26-2009, 03:10 PM
Rasp Rasp is offline
I know that was awful. I'm reading the forums with my young son and this filth shows up.
Disgusting.
lol
Old 09-26-2009, 10:34 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
I apologize, I did not intend to offend anyone! :sarcasm1:
