Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-09-2009, 05:26 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 95 eclipse, stutters while accelerating more than half throttle
The high idle would be caused by a vac. leak somewhere. You may have actually caused a leak somewhere. Just google how to clean fuel injectors, to have them cleaned properly you have to pay someone to do it but you should be able to clean them a little bit
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-09-2011, 04:30 PM
1999eclipse 1999eclipse is offline
Hey Im having the same problem on my car, bro did you find the solution??
ive done the plugs, wires, ignition coil
i was thinking of disconnecting the egr - But i have no idea how to do that, i can't find a diagram for a non turbo 99
but the car idles fine, its only when i press the gas pedal more then 20%
Old 02-09-2011, 04:34 PM
did you find out what the problem is, i have the same prob
Old 02-10-2011, 05:38 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Welcome to AF! The original poster hasn't had any activity for almost a year now, so I doubt you will hear back from them... However, we can try and help you troubleshoot your problem.
So your car also stutters while giving it throttle? If you have already done plugs, wires and coil then the next thing I would check would be your battery and alternator to see if it is supplying enough voltage. If that all checks out fine then I would look more at the route of possibly air intake sensors... Possibly a bad MAF or MAP sensor?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
The Following User Says Thank You to Blackcrow64 For This Useful Post:
1999eclipse (02-10-2011)
  #20
Old 02-10-2011, 06:54 AM
ned032002's Avatar
ned032002 ned032002 is offline
Your stock GSX already has a blow off valve. If you want to replace it with an aftermarket one, you will need to have your stock pipe flanged. Your going to want to start learning as much as you can about these cars. Check out www.vfaq.com for any help with modding and google/search for any questions you have for future modifications. Be sure to start a new thread when you have a question or just start a "Project Thread" and you can post pics and ask any questions you want in there. Welcome to AF!
Old 02-10-2011, 08:44 AM
ok i just changed the battery a couple of months ago, ill check the alternator and the mass air flow sensor, and try again, thanks
