Old 08-14-2009, 05:45 PM
grayfox2014 grayfox2014 is offline
Re: 1957 Ferrari Testa Rossa
Originally Posted by CrateCruncher View Post
Nice start Grayfox,
The stretched sprue was a good solution. Don't be too harsh on those plastic wheels. I bet if the chrome were stripped off, airbrushed with X-11 and a tiny amount of X-19 smoke they would look pretty good. Real TR wheels are usually painted matte silver for racing.
The kit wheels aren't bad, but not great. The spokes are way to thick and too few. Im glad you pointed out the fact that on the real cars the wheels are painted. I had to run back t my reference sites to get a better look. So I will be painting them soon.
http://www.supercars.net/Pics?viewPi...D=1&pID=865718
Thats right. It's called hydrogen embrittlement: The plating process causes hydrogen atoms to get lodged into the crystal lattice of the base metal preventing them from slipping. Embrittled spokes will snap like a dry twig. Materials folks discovered that by baking recently chromed parts for a while at several hundred degrees they could drive off the hydrogen returning the base metal to it's former ductile state. I didn't think anyone would care about the reason so I kept it short.
Just to expand a little and to show off. The parts that you see on old Formula cars that look chrome plated is in fact nickel plated. This nickel plating is used to protect the metal from corrosion. Chrome is in fact three layers. First is a copper, this can be smoothed down to a nice finish. Second, the nickel plating. The last plating is the chrome, this gives the lovely high shine finish and the light blues tint.
Steve
Current WIP: http://www.automotiveforums.com/vbul...d.php?t=961980
Old 08-14-2009, 06:51 PM
tony126c2 tony126c2 is offline
Thanks Steve!
Old 08-19-2009, 02:46 AM
So I have made some progress since my last post. I've decided that I going to really push myself with this build and try thing I have wanted to but have been to scared in the past. What makes this build different? I think it is i have you guys to help me out when ever I get stuck. Well no back to the build. I decided to redo the wheels and paint them silver. This made a huge difference in the look. Thanks for pointing this out CrateCruncher.
In this build I have decided to "open it up" so im opening the doors, trunk, and fuel cap. The sides had to be glued in before I could take the door out because i would then have two halves of a car and then have to make sure everything is straight.
With opening up the trunk this also means I have to build a new gas tank, cut out the floor panel, and build up the frame to be correct.
Here is the cut floor panel, I guess there is not turning back now
Starting to build the frame. Thankfully most of the frame is correct, just a few pieces need to be added
I started to stare at my reference guides again and found some body work that needed to be fixed. About 7 different louvers or holes over the body. The easiest to build was two air ducts under the doors.
Second easiest was two holes to exhaust air out the back of the body
The hardest to do is three that are up on the hood and right in front of the drivers dash.
Thats all for now, Im going to start working on the hinges (a first for me) for the doors and the rear deck lid. I need to find a small spare wheel to fit in the trunk. This is going to be that hardest part to find because its a odd size, the normal tire doesn't fit well inside. Once I find that spare I need, I can continue building the frame and start on the gas tank (scratch building, again a first). The suspension will be started soon with a spring rebuild (which once again be a first for me).
Please all comment welcome, good or bad.
Steve
Old 08-20-2009, 09:48 AM
CrateCruncher's Avatar
CrateCruncher CrateCruncher is offline
Wow! Very nice Steve. If your tank compartment is like my TR, you may be able to get by with just a tire for the spare. When in place the only part of mine showing is some tread and sidewall.
How did you paint your wheels. Any problem with adhesion to the metal?
Old 08-20-2009, 11:22 AM
Looks very good Steve! But I look at the reference pics I should say that the tubing is a bit to thick. This can cause to little space for the gas tank which is placed on top of the tubing.
Old 08-20-2009, 12:58 PM
250 Testa Rossa 250 Testa Rossa is offline
Hmmmmmm. Let me guess... You're building it as Chassis no. 0714 TR a.k.a. The Black Hibiscus
Old 08-24-2009, 04:30 AM
CrateCruncher, as I was looking at my reference pics trying to figure out what the supposed to build a gas tank and whats it needs to look like (see below) I found out this car does not have a spare. I guess its because this car was mostly used to SCCA races and no need to have a spare on only a 3 mile course unlike the 8 miles of LeMans. And I had no problem what so ever painting the wheels. I used Tamiya paint and sprayed them with a couple of lite coats fallowed by one wet coat.
Tony, Right after I read your comment I ran down stairs to look at the frame praying it wasnt so. Well the tubes still look right to me. I believe it must be my camera that makes them look big. It must be the great quality of this 12 year old digital camera and why half of my pictures come out blurry .
250 Testa Rossa, Yes it is chassis 0714, I watched it roll across the auction block and decided that I had to build it.
Well now on to what I have been up to. I decided that I need to practice my airbrush and polishing techniques. So I grabbed my mouse (my computer mouse) So I made myself my own Mousa Rossa . And yes I am currently using it.
And now on to the build. First off I decided to rebuild the spring to make them look a little better. I found a picture of the under carriage, and it shows only springs. No shocks....I was shocked (Im sorry I could not resist). So this made it a little harder to build now that it had to be free standing with nothing in the middle to make them straight.
With the springs out of the way I was able to start scratch building the tank. Im not really sure why I decided to build the tank the way I did but it wasnt to bad. I was able to use thin styrene and wrap the outside piece all the way around to forum one smooth piece.
I first cut out the sides of the tank and the middle of the tank that would wrap all the way around. Making many different sizes and shapes see which ones I wanted to use.
I then used Tenax to weld the tank sides and outside together.
I put some pieces of styrene rod in the middle to stiffen up the side to i could put pressure on it with out worrying.
And the finished tank. I was able to trim the plastic to leave a small lip around the entire tank to simulate the real tank.
I will end up putting rivets, the tie down straps, gas cap, and fuel lines on at a later time. While I was waiting for the tenax to harden up i decided to read the label...Just read it.
Teaches me to read labels. If anyone is still want to sue this stuff you might want to pick up as much as you can because the company that makes it just went out of business (there goes micro brushes also)
The final thing I needed to do was making the brass doors and gas filler door on the trunk.
Next I will get the hings done so I can start painting the body and finish the suspension to make it look like im getting some where.
Thanks for watching, and once again all comments are welcome (hopefully constructive comments)
Steve
Old 08-24-2009, 05:28 AM
Hi Steve,
Great progress..everything looks very good!
That is good Maybe the angle distorts the image. I will give them the same size as the arch.
Ton
Old 08-24-2009, 08:27 AM
godfather23's Avatar
godfather23 godfather23 is offline
Great effort you put into this build. If the TR looks like your mouse it will be stunning.
Nice WIP-thread. Very entertaining and informative. Thanks.
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 08-24-2009, 03:12 PM
Nice progress Grayfox. If this is a race I think your in the lead position now (and had time to test your colors on your mouse!). We need to poke Ton for an update on his beast.
Regarding that Tenax label: It only affects the Californians, everyone else is immune.
Old 08-24-2009, 06:24 PM
I didnīt do nothing for a couple of days now. And I am stuck on a rather vital part of my rebuild: the "hump" on the trunk. When I make a paper mould of the hump and cut it in two and put it back it does not fit anymore
Someone is making a 3D drawing now for me which you can convert to a flat mould which can be used to cut out a piece of brass/copper. I also ordered some goldsmith tools to manipulate the metal. If I am not able to do the hump in good quality I will stop the rebuild and finish it OOB.
So have some patience with me
Ton
Old 08-24-2009, 10:45 PM
The Black Hibiscus lives !
Old 08-25-2009, 07:46 PM
gtziaf's Avatar
gtziaf gtziaf is offline
Great WIP-thread.
Thanks for all useful details.
Good luck until the finish...
Old 09-01-2009, 04:09 PM
Hobby Shop Owner Hobby Shop Owner is offline
Steve,
Just so you know, I think you're doing a great job on this one. BTW, the pictures of the body on the frame show the additional frame members you installed in their proper profile, and I think they look like you got them right. Now get back to the bench and send us another update.
Jeff
Old 09-02-2009, 09:31 PM
Motion3174 Motion3174 is offline
Not for the squimish Ferrari TR fan...http://www.autoblog.com/gallery/ferr...y-historics/#6
