Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 07-28-2011, 08:59 PM
laflega laflega is offline
Re: Removal of cylinder head
Just send you the file through adobe online. You will need a crow wrench 41mm, an angle torque meter and a torque wrench. Be sure to replace the idler, the tensioner and the water pump. Ensure that all your timing marks are in line where they are suppose to be. The camshaft tends to move because of the pressure on the valves. You do not have to buy a camshaft holder tool. I just used zip ties and tied the camshafts together with the timing marks properly aligned. It just worked find. take your time and you should be OK. MAKE SURE ALL YOUR TIMING MARKS ARE IN ALLIGNED PROPERLY. Once you have everything in line, rotate by hand the crankshaft with a ratchet to ensure after a few rotations your marks are in line. Good luck.
Old 09-01-2011, 04:46 PM
ohrt ohrt is offline
Laflega; Can yoo send methat file too. I have an 04 and mechanic is quoting me $2300 for head, timing belt, surpintine, thermostat and housing, water pump, tensioner, plugs. I figured $900 in parts. Hope someone can help with instructions. [email protected]
Old 09-08-2011, 08:32 PM
I just sent you an EMAIL address where you can get an electronic copy of the service manual for the 2004 AVEO. It is less than $20.00
Old 11-29-2011, 08:44 PM
wheelnuts66 wheelnuts66 is offline
I'm in the middle of removing the head on my 04 aveo. I'm wondering. Do I have to remove the intake manifold in order to get the head off. Thanks for any info.
Old 01-04-2012, 06:40 PM
dakotadog dakotadog is offline
can you please send me a copy as well. [email protected] I have an 05 with 50K on the clock that broke the timing belt.....
Old 01-26-2012, 02:10 PM
racefan0824 racefan0824 is offline
I could sure use a copy of the pdf file for the head removal on the 2004 aveo.
[email protected]
Old 11-12-2012, 09:45 AM
tya2agt tya2agt is offline
please send the pdf file on removing the aveo cylinder head to [email protected]. Just destroyed my second aveo engine with another bleeping timing belt failure. Decided to rebuild the head myself now that junker engines are over a grand a piece
thanks Rocky
Old 11-23-2012, 10:02 AM
mark05aveo mark05aveo is offline
can i get a copy of the head removal link on a 2005 aveo. [email protected]
Old 01-20-2014, 04:24 PM
djmarch djmarch is offline
Me too [email protected]
Thanks....
Old 05-14-2014, 06:29 PM
miller330i miller330i is offline
I would like that info as well! I will be doing the head rebuild next week Thursday. Thanks!
Old 09-22-2015, 06:23 PM
Sevios Sevios is offline
Hey I have a 2005 Chevy Aveo which had the timing belt go. There is internal damage but i will not know how much until I get inside. I would love to have any help with diagrams on how to remove the head and fix damage. My E-Mail is [email protected] Thanks
