Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-31-2009, 08:31 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: 90 olds ciera struggles when warm
going to work on today ill post what results i get.
Old 06-07-2009, 09:47 AM
jackass#1's Avatar
okay, im at wits end with this. tool new regulator back and exchanged for another, still same problem. should i start looking into the ignition system? could i still have a faulty censor even if there are not any trouble codes stored?
Old 06-07-2009, 10:52 AM
Mrbizness1 Mrbizness1 is offline
You need to find a shop that has a computer laptop program they could hook up to your vehicle's ecm connection under the dash. Then you can drive the vehicle while it is hooked to the computer and they should be able to pinpoint the problem. I had this done to our company truck that had a intermittent hesitation problem for months. Within a mile of driving the computer found a defective MAP sensor and the problem was solved.
Old 06-07-2009, 04:07 PM
jackass#1's Avatar
it doesnt stay running long enough to drive. still no trouble codes stored in ecm. found a parts car going to change out the throttle body and all censors on my next day off. parts car ran good a friend of mine drove it til the block cracked, so i now its a good sorce for parts.
Old 06-07-2009, 06:22 PM
FYI Not all trouble codes are stored in the ecm. Good luck with the swapped parts.
Old 06-09-2009, 12:13 AM
jackass#1's Avatar
cleaned maf and idles and drives great. just drive for a mile. going to replace and test drive further.
Old 06-14-2009, 05:18 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
if your regulator was bad and just pouring fuel into your manifold, it'll take a bit before it all clears out and the engine cleans up and runs fine...also you may have a fuel injector that is stuck open. if you check fuel pressure, then turn the engine off, does the pressure stay, if the fuel pressure leaks down to 0, and you just replaced the regulator, You may want to check your injectors
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
