Old 05-05-2009, 07:13 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Best Drop in Paper Air Filter
I noted that S&B sells the cotton gauze oiled type drop in air filters too. Has anyone tried one? Still expensive at around $32 but I think cheaper than the K&N brand.
Timeslip 08/12/06
AF Community Guidelines
Old 05-05-2009, 08:23 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Good info here guys! Thanks for all the feedback.
I to have ditched delco since they started being made by champion. However I am currently running a delco oil filter on the GTP becuase I plan on changing the oil again within a few hundred miles after my LIM gasket change.
I think from here on out I'm going with wix filters.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-05-2009, 08:25 PM
tblake's Avatar
In God We Trust
I am not quite sure if I have asked this before or not, I think I have, but I dont remember the answer...
A bit off topic so sorry for hijacking this thread.
What do you guys think about running a longer oil filter on our GTP's? The stock filter is a PF47, isnt the longer one a PF52? If I could get a wix equivelant of the PF52, what would be the advantages/disadvantages of running the longer filter?
Old 05-05-2009, 09:18 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
No real advantage, same efficiency as the short one, the only advantage may be the extra capacity which is a moot issue if you change oil/filter on a prescribe basis.
Old 05-05-2009, 09:28 PM
tblake's Avatar
In God We Trust
Thanks! Thats what a figured. Maybe possibly will it help keep the oil a little cooler?
Old 05-07-2009, 08:50 PM
tblake's Avatar
In God We Trust
Ok guys, I changed my air filter to a wix. The old one was a cheapo microgard. Note the different amount of folds in the filter area between the two.
Old 05-07-2009, 09:41 PM
doctorhrdware doctorhrdware is offline
The pleats on the wix air filter look like that they are tighter and more of them. How much was the wix air filter.
Old 05-08-2009, 07:30 PM
tblake's Avatar
In God We Trust
Exactly my point. I'll bet it can filter a higher volume of air.
I think the Wix was 14 bucks at oreilly's.
Old 05-08-2009, 10:22 PM
With more surface the better the air flow will be. So I guess I will be buying Wix air filters also.
