Old 04-18-2009, 10:05 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: GTP Fuel Injectors
No it wont come out the bottom.
I'd be afraid that it fell inside the cylinder head, then if you try running it, it could hold the valve open, and worst case scenario piston dig the valve....
I dont know. I would feel inside the cylinder head with a small screwdriver.
from the pic, it looks like you're going to need a couple new injectors.... But lets see what Bob and Rich say.
http://www.zzperformance.com/grand_p...=249&catid=113
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-18-2009, 10:15 PM
597GTP 597GTP is offline
wow, them injectors are expensive. the price they show, is that for one or for six of them? not a good time to spend that kind of money.
Well if it did fall inside would it still be in there?
Old 04-18-2009, 10:21 PM
tblake's Avatar
In God We Trust
I believe that price is for the 6. Believe it or not 250.00 for 6 is a darn good price for injectors. Last time I had to replace one in a cadillac, a single injector was 100 bucks.
If it fell in, it would be sitting on top of the piston just waiting for you to turn your key and mess things up.
I don't know man, You've stumped me. I dont know what I would do.
What year is your car again? 2002? strange!
Old 04-18-2009, 10:27 PM
yes, tblake its a 2002 GTP
man you have me worry now.
I feel like tearing apart again.
also, why do we need to change the oil and filter when we do a LIM gasket change?
sorry for all the questions, but this is my first biggest job ive done on a car.
Old 04-18-2009, 10:29 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Please try to keep your posts in one thread without starting new ones based on the same issue. It gets confusing, causes redundant replies and more work for people to weed through the discussion.
Your post concerning fuel injectors has been merged with the LIM gasket post.
Timeslip 08/12/06
AF Community Guidelines
Old 04-18-2009, 10:30 PM
Re: LIM gasket
ok, sorry about that. I just replied .
Old 04-19-2009, 10:25 AM
tblake's Avatar
In God We Trust
Re: LIM gasket
You need to change the oil because of all the leftover gasket material, dirt, and crud you wiped off before you installed the new gaskets.
It is recommended to change the oil and filter again after 500-1000 miles once the job is done.
I dont know what to tell you about the injector seats.
Old 04-19-2009, 10:33 AM
BNaylor's Avatar
Re: LIM gasket
If there was any coolant contamination in the engine due to bad intake gaskets then I would run some Seafoam engine treatment through it into the crankcase and then drain the oil and add a new filter.
The reason why our GTP fuel injectors are expensive is because they are rated at 33# (lbs) of flow, actually 36# but 33# advertised.
In comparison for the NA SII 3800 engine injectors are rated at around 21.5# flow.
Timeslip 08/12/06
Old 04-19-2009, 11:35 AM
Re: LIM gasket
ok, Im going to change the oil & filter , and put in regular 10w30, then like you said after 500miles, Ill change it again but this time I'll be throwing in my synthetic oil along with the matching filter by Mobile.
As far as the injectors go, can I buy some used ones for the time being?
I see zzp has some for $99 from old L67 engines.
Old 04-19-2009, 11:45 AM
BNaylor's Avatar
Re: LIM gasket
Originally Posted by 597GTP View Post
As far as the injectors go, can I buy some used ones for the time being? I see zzp has some for $99 from old L67 engines.
That will work if you want to save money or try Ed Morad Parts Company on EBay.
Timeslip 08/12/06
Old 04-19-2009, 11:50 AM
tblake's Avatar
In God We Trust
Re: LIM gasket
Good thinking to replace the faulty injectors.
Old 04-19-2009, 11:58 AM
Re: LIM gasket
Thanks guys for your help & feedback.
It sucks seeing my car in the garage waiting to be put back together.
and I guess the next question will be, how to remove the injectors?
and another thing I didnt do before removing the fuel rail, was that I didnt release the pressure, from it. Is this ok?
I believe I have to drain the fuel , before I remove & install the new ones correct?
Old 04-19-2009, 12:06 PM
tblake's Avatar
In God We Trust
Re: LIM gasket
You will be fine, you dont need to drain all the fuel, but if you havn't disconnected the rail from the lines, you will have to release fuel pressure at the schrader valve.
The just pull the clips off from the top of the injectors, twist slightly, and pull. The injectors should just pop right out.
Old 04-19-2009, 12:10 PM
Re: LIM gasket
thanks tblake,
all I have to do now is wait till tuesday now i guess.
I will order the used injectors from zzp tomorrow and have them ship next day.
I will keep you updated on how everything went!
Thanks again,
Old 04-19-2009, 12:18 PM
tblake's Avatar
In God We Trust
Re: LIM gasket
Before you do that you should check around to local parts places. You might be able to find a new injector for a better price that zzp's used ones plus next day shipping.
