Old 04-16-2009, 11:15 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: Weird Noise COming from Engine
Mine doesn't have a shim.
Still, if something was grinding against the starter it should be happening all the time, not just on decelerating.
You might just mount the starter without the shims and see how it reacts. That is a bit easier than removing it while its running.
I'd still do a compression check though... and doing so will give you an opportunity to have a look at spark plugs.
Old 04-17-2009, 06:29 AM
dwbailey dwbailey is offline
Thanks big guy. My friend is coming by this afternoon and we are gonna put it on jack stands and run it and see if we can isolate the sound better than tranny shop was able to. Will suggest to him we do the compression test and maybe take the shims out and see if that has any impact.
Old 04-17-2009, 08:53 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I've never had my starter off so I don't know if I have shims or not. 297,000 miles!
Nevada Tumbleweed
Old 05-02-2009, 01:55 PM
autotech234 autotech234 is offline
I would say allmost 100% that it is your flex plate. I have diag. this tipe of noise and you simtoms fit to a T. Trans will have to come out to replace.
Old 05-21-2009, 07:07 AM
Well it was in fact the flex plate. The place where it bolts to the engine right around the outside of the bolt holes was cracked all the way around. Heaven only knows why it stayed together. Tranny shop I use charged me close to $400 to replace but I guess being that the tranny has to come out to get to it plus the part, that wasn't too bad. Thanks guys for all the suggestions/info. I love this place!
Old 05-22-2009, 09:32 AM
Davescort97 Davescort97 is offline
Escort guy
Thanks for coming back and letting us know what it was. Hopefully your thread and posts will help somebody else. Glad you got it fixed!
Old 05-22-2009, 09:43 AM
I hope it does help others. It was funny how mine just made the noise when revving it up and when especially when I would let the engine slow me down on a down hill situation. I have no idea why it didn't come apart. The good Lord was with me on it for sure. The way it was cracked TOTALLY around the bolt pattern shows that there was nothing holding it together. Oh well. Have a great holiday.
Old 05-23-2009, 05:48 AM
dlbdata dlbdata is offline
Any chance it is the exhaust system? Mine was making a rattling noise, turned out it was a piece at the front of the catalytic converter was rattling around. It was an where the cat attached to the front exhaust, kind of a ring of rusted metal, I guess to strengthen the attachment. I actually cut it off a couple years ago, its been fine.
Old 05-23-2009, 08:23 AM
denisond3 denisond3 is offline
I have had the starters off of both of my Escort 1.9's, a 92 and a 94. There were no shims. Also I dont recall any shims being mentioned in the OEM service manual for the cars.
Old 05-23-2009, 08:29 AM
Carsrcool100's Avatar
Carsrcool100 Carsrcool100 is offline
Is there something wrong with the tranny??? Or is it a problem with the car censor?
Old 05-27-2009, 06:39 PM
I wouldn't say there was something "wrong" with it. Not real sure why the flexplate (flywheel) cracked all the way around the outside of the bolt pattern. Just darn happy I got on it before it broke all the way and who knows what the end result would have been. A lesson to not procrastinate weird noises coming from the car.
Old 06-10-2009, 08:06 AM
badpoor badpoor is offline
Please check the bracket comming from your tranny to the exhaust pipe.
Mine was making a similar noise and I found a crack in that bracket.....just get it welded and that noise should go away.
Old 06-10-2009, 08:44 AM
That may very well be a reason they can make a noise but not in my case. It was for sure the flexplate. I made them give me the old one.
