Go Back   Automotive Forums .com Car Chat > Chevrolet > Uplander
Old 04-09-2009, 09:21 PM   #16
spike88
Banned
Re: Uplander electric brake control installation
Originally Posted by rhandwor View Post
.... Also search Champion trailer wiring diagrams.
Found: http://www.championtrailers.com/Elec...l%20wiring.pdf
As seen within this PDF file, they show a Brake Peddle Switch in their diagram as well. Is this the diagram you were referring to?
spike88 is offline   Reply With Quote
Old 04-12-2009, 01:15 PM   #17
spike88
Banned
A few moments ago, I "finally" completed the Husky Excursion Brake Controller ( http://www.huskytow.com/FTP/PDF/H-2-A_ELECTRICAL.pdf ) install in my '09 Montana van. With thekingarthur's provided BCM C2 Connector and Pin 30 location details (via direct Email attachments to me) I was able to connect my vehicle's BCM-C2-Pin 30 "white" wire to my Husky Brake Controller's RED wire. As planned, my Brake Controller install went "as planned". Slow progress (due to my first time learning curve) but in the end, the newly installed Brake Controller is now working great.
For lots of install pictures, surf:
http://s178.photobucket.com/albums/w...afilter=images
Note: Unfortunately, I did NOT take the extra time to test the "volt variance" states on this BCM's C2-Pin 30 "white" wire. I only tested my 12V "light probe" to confirm 12V present status when Brake Peddle Pressed and NOT pressed. Since +12V when brake peddle pressed, I didn't bother testing volt level for its peddle "unpressed" state.
Hope these addditional uploaded pictures help in your van's Brake Controller install as well....
Old 03-06-2010, 05:45 PM   #18
Corvetter
Hi thekingarthur and spike88. Sent you a PM. Please send me the details on how to identify the BCM C2 Pin 30 white wire on my harness. Thx!
Corvetter is offline   Reply With Quote
Old 03-06-2010, 08:26 PM   #19
spike88
Banned
Hi there...
Yes. I received your PM. Unfortunately, the email portal on this forum doesn't send .PDF file or other attachments. Thus, I sent you a PM (containing my direct email id). If you send me your email id (directly to my email id), I can sent you lots of pictures and other supporting details. Onr of those "this is how it worked for me" detailed info shares...
If wondering, the Brake Controller in my 2009 Montana van works great. Once installed and its wires wrapped with plastic loom, its been working great. Glad I "took the quality time" to install the electric Brake Controller in my new van.
Looking forward in receiving your direct email id (re: by sending email to my direct email id).
Old 03-06-2010, 08:44 PM   #20
Corvetter
Originally Posted by spike88 View Post
Hi there...
Thanks spike88, I sent you an e-mail right back.
Old 03-06-2010, 11:31 PM   #21
spike88
Banned
Hi Corvetter.
Approx 1 hour ago, I sent the text info (and attachments) to your provided email id. If you do NOT receive my email text and several attachments soon, please advise. I will resend again. If wondering, the provided .PDF file (details on BCM C2) is most critical - for your needs.
Hope this helps your van's Brake Controller install task as well....
Old 09-26-2010, 04:40 AM   #22
moneeleann5
Hi guys.
Any chance I can get those diagrams sent to me as well? I'm trying to install and electric brake controller on a 2008 uplander next weekend, and I'm trying to get everything together for it.
Thanks!
moneeleann5 is offline   Reply With Quote
Old 09-26-2010, 11:41 AM   #23
spike88
Banned
Originally Posted by moneeleann5 View Post
Hi guys. Any chance I can get those diagrams sent to me as well? I'm trying to install and electric brake controller on a 2008 uplander next weekend, and I'm trying to get everything together for it. Thanks!
Hi there... A few moments ago, I emailed you 1 email msg with lots of URLs and 7 attachments. If you do NOT receive this email within the next few days, please send me another PM (Private Message).
Also... When gathering parts, remember to get a few 3/8" (or so) grommets as well. Like you, I proactively had all the electrical parts but didn't have the rubber grommet (for vehicle's firewall hole). Lesson learned as well...
When doing your Brake Controller install (from scratch method), remember that old racing turtle. re: "Pace yourself - slow and steady". If needed, take time breaks between each phase as well. re: Complete 7 pin install, then take a break, install 10 gauge wire under the vehicle, then take a time break. Slow and steady - since high quality within its install is very critical.
Hope this helps...
