#16
Re: Help Help. I screwed something up
It runs but ticks from the cluster unless i step on the emergency brake or unplug the cluster. Any ideas. it works and everything it just ticks real fast and loud.
#17
Sounds like there is still an issue somewhere. The clicking sounds like the DRL relay. By you stepping on the parking brake and the clicking going away sort of coincides with the drl system. (ie drl's go off when you apply the parking brake).
Check the DRL fuse in the glove box. Bet its blown.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#18
I knew Tblake would have an answer.
#19
You are a GOD . I mean seriously I love you, it runs great and know its also quiet. Life is good and know i can once again sleep
#20
You guys are funny! I'm only sharing my previous knowledge mainly because most of these problems I have encountered in the past and had to diagnose myself. (been there done that).
So I'm more than glad to help out whenever I can. Chrissbee, does the new install of the digital DIC work? If so, then job well done.
#21
It does not work but i think it was already broken im going to get another one and try again. The Car runs great though so im back to the analog DIC. I did check the DRL fuse behind the glove compartment it's not blown. But there is a black box above the emergency brake that has two connectors i unpluged the smaller blue one and the ticking noise has stopped and if you plug it back it starts up again so im sure that whatever the part is called is now fried. but she runs
#22
Well as long you can get from point a to point b I would call that a success.
