Old 03-25-2003, 05:58 PM
streetrex streetrex is offline
eh, by the way, anyone know how to change that shit on the bottem of my post? that shit about "anyone knowing about a b18 engine" i'd appreciate it if anyone could tell me how to update that..thanks
91 crx for sale
automatic
motegi 16"
clear corners and bumper
around 6 1/2 infinity ref.
weapon r coilovers, ingalls camber(front)
very little rust on rear left quarter panel
Old 03-25-2003, 06:02 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Click on "Profile" at the top right of the screen, then click on "Edit Profile" and there'll be a box where you fill in all that crap.
Old 03-25-2003, 09:02 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
how much for the Si distributor? Help a brotha' out. Swap looks good. 75 shot will be nice with that setup.
Old 03-26-2003, 03:07 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
WOOT!
Looks nice!
Old 03-26-2003, 03:16 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
thanks for all the kind words... as someone replied, the hasport kit only requires three mounts. We took off the front mount cuz i felt it would be easier to put the motor in that way...
todd: to ground the oil pressure switch, i extended one wire to the negative terminal on the battery... the intake is stock, it came with my motor.. i had to cut off a piece of my old intake though to clear the battery and stuff that into the intake...looks pretty trick...the stock intake is about 3" diameter anyways so I'll be alright for a while...
i just have a rear section muffler... sounds and moves pretty good..
the garage was kept pretty clean because after every day, we just picked up everything and swept up...im a neat freak ...only reason i took most of the front end off was to have easier access to everything, plus i didnt want to scratch anything any more than it already was,
the swap coulda been done in a weekend really, but i ran into some problems with having the wrong parts for the type r intake and the wrong timing belt/waterpump clutch.... plus we took our time to do it right...
to emil: an a2 swap is prob a lil more complicated unless you use a cable trans... good luck and make sure you have evrything you need b4 you get started... its a pain to go out and search for parts when you have no car to drive...
to seth: what are your plans for the zc???
ihaveanstd: my old d16 is currently spoken for... if he doesnt come thru i'll hook you up
Old 03-26-2003, 03:25 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Hey good job man, looks like you done it pretty well
Cheerz
Jim
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 03-26-2003, 07:55 AM
1990civic's Avatar
1990civic 1990civic is offline
hey what do you plan on doing with that d16 engine?
email: [email protected]
Upgrades:
Si Interior
Painted Interior
TACH
WW Body Kit
Clear Tail's (no altezza's here)
http://www.automotiveforums.com/img.php?129408DSC00972.JPG
****hopefully not the end****
Old 03-26-2003, 08:51 AM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
Question
jNYCe5, I got a couple of questions for you. What kind of cams do you have? I have a B16 and I am looking into geting some cams. When you put the cams in, did you get cam gears too? My friends say that if I get cams, that I should get cam gears to tune them out. How hard was it to put that manifold on? I was thinking of getting a Skunk2 intake manifold... do you have any suggestions? One last question... I need a altinator belt pretty soon, cuz mine now is all dry rotted... is there any other cars like a 90-93 Integra that their belts wil work, or will I have to get a 99-00 Si altinator belt? Thanx a lot for your help.
By the way, your swap looks real good, and let us know what you run at the track. :flash:
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 03-26-2003, 02:37 PM
i have itr cams and i had skunk2 cam gears... put em in at the same time....manifold bolts right up with stock gasket, just make sure you get a fuel rail and eavc like i said in my write-up... skunk2 intake is good, you can also look at getting a type r integra intake...
the 99-00 si alternator belt is shorter and will work just fine...
