Old 01-17-2009, 07:50 AM
bracketshark bracketshark is offline
Re: tdc after eplacing head gaskets 4.3
Hey duh1, I'm in Florence (SC) and know a fellow that's got a good 4.3 if you end up needing one. I think it came out of a ~95 blazer., anyway He wants $600 for the engine and 700r4 transmission hooked to it, just thought I'd throw that out there as an option. I bet there are a lot of busted blocks around here after the temp. last night, we're not used to this. Good luck with the repair.
Old 01-17-2009, 10:33 PM
duh1 duh1 is offline
sorry for the late reply, but it's a 94 auto 4.3 c/k, a tad over 200k miles. a year ago it was overheating, so i did a valve job thinking it would also cure my overheating probs. it worked well for a while but i kept having sensor probs because the guy i paid to do the job sent the sensors to the machine shop with the heads. long story short i broke the cardinal rule here, i did not send the heads to be checked after this last overheating bout. after replacing head gaskets this week water was in 5 of 6 cylenders, commpressio test today ranges from a low of 60lb on #1, 90lbs on 2,3,&4, and betwee 110 to 150 on 5 and 6. so, i'm taking the heads to the shop for magnaflux and warp test, the valves and springs are just a year old so i'm not to worried there, will have them tested though. thanks to all that responded, looks like this one is gonna take more time and money
Old 01-18-2009, 12:07 AM
tempfixit tempfixit is offline
Just a thought, have you by chance tried retorquing the head bolts. Could the head or intake bolts be streached from being overheated causing your problem? I know on some engines it is required to install new head bolts whenever heads are removed I do not know if this is the case on the GM's or not.
Old 01-18-2009, 12:58 PM
I have never replaced chevy head bolts, but i guess they could streach. also, if oil and water have gotten under the gasket surfaces i don't think retorquing would help. besides if i take it down that far i might as well replace the gaskets and get the heads checked
Old 01-18-2009, 04:25 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Best to install new head bolts any more.
There were also a few years that had bad head bolts.
I have saw some break off.
Good Luck
MT
