#16
Re: engine misfire on all cly's and rattle on top of 05 3.4 engine
so at idle no noises...when it rev's the engine is rapping and at high rpm its missing as well...
I believe it is engine damage.....let us know what come apart.. |
#17
Re: engine noise after oil change/sticky lifter maybe,can some one help me
yep know exactly, bolt holding down rocker arm broken, just cost me $3000 to replace with used engine with 36k. also included changing dexcool to green stuff, and replacing intake gaskets and main seals just to be safe |
#19
#22
That's not uncommon on the 60º Chevy V-6 engines when they are over-revved when cold. NO engine should EVER be subjected to that kind of intentional abuse, but these engines are particularly susceptible to thick oil pumping up the lifters and popping the rocker bolts:
![]() Pull the rocker cover and you might find this same image. Instead of engine replacement, I've had good success with several of these by installing ChrisLyn stainless thread inserts in the head and bolting it back together. P/N 82160 should be the correct 8mm insert for that application.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide Last edited by Blue Bowtie; 11-22-2014 at 06:57 PM. |
#25
I'm still curious to see what brand(s) oil filter was installed since the problem occurred after an oil and filter change. For example the AC Delco PF47 oil filter and Fram equivalents have been known to cause a similar issue the OP is having. Poor oil pressure or defective anti-drain back valves. Both the VIN "J" 3100 and VIN "E" 3400 engines are susceptible to piston slap which in a worse case scenario could cause sufficient crankshaft variation and misfires. GM no longer makes the Delco oil filters. Now made by Champion Labs based on the crappy Ecore design.
#26
Re: 3.4 missing and rattleing after oil change,help
i |
#29
they must of changed the camber, and this could also be from bending some componet in the steering...if they disturbed the struts you will need an alignment and this should be covered since this was messed up on the engine repair..
