Old 06-24-2013, 11:14 AM
j cAT j cAT is offline
Re: 06 silverado p0449 code
Originally Posted by fdmille View Post
I had a P0449 code on my 2008 Silverado crew cab and used ACDelco 214-2082 Canister Solenoid Valve Kit to fix it. I did not need to use 5/8 heater hose as others have used, because with a little bit of silicon spray and a bit of wiggling and pulling, I was able to get the original hoses off in reusable condition. However, I did cut off the hose connectors on the bad solenoid valve and crushed them in a vise, which made it much easier to get them out of the hoses.
The valve is located in front of the gas tank under the middle of the truck on drivers side.
when working the engine intake system/vapor do not use any silicone products. silicone damages the O2 sensors.
use soapy water or a WD-40 product.
Old 11-07-2013, 01:19 AM
tamabear tamabear is offline
I hope some one can help me . I have a 2009 Silverado with the engine light on. the code says small emissions leak. did the smoke test and check the purge valve couldn't find a leak or problem anywhere! and yes I put a new (from the dealer) gas cap on and reset the light and it still came back on. any thoughts?
