Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-13-2008, 08:03 PM
FL 3.2L FL 3.2L is offline
Re: 98 rodeo coolant leaking
A gallon every other week?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-14-2008, 07:55 PM
duke36 duke36 is offline
Im thinking its more than that...I have to drive 10minutes to and from work every day. If I fill the reservoir up its empty in about two days.
Old 12-15-2008, 04:43 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Maybe there is a crack in the reservoir?
it is pretty easy to pull out and check.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-18-2008, 11:36 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Hard to believe you're losing that much and not seeing it somewhere.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 12-19-2008, 01:05 AM
Ramblin Fever Ramblin Fever is offline
If you're losing THAT much, I'd say the engine is consuming it, even if the oil is clean.
Unless you do have a bad radiator, but even then, you should be able to see *something* green on the frame underneith.
Same thing occured on my late Toyota, coolant kept running away, never could find it anywhere obvious, oil was clean too....til we opened up the engine cause it refused to finally start. Whole entire bottom-end was swimming
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 01-19-2009, 02:51 PM
still havent found the leak to this day....no coolant in coil packs so im guessing a blown head gasket maybe..can anyone think of anything else before i take it to the ol dealership for a high price diagnostic?
Old 01-19-2009, 04:44 PM
Florsuzo Florsuzo is offline
If you aren't seeing any leaks then the engine must be consuming it.
Are you in a place where steam comes out the tailpipe every morning?
Try a pressure test when the engine is cold. Most likely you have a pinhole or tiny crack in the head near the exhaust valve and when the engine is warming up it's burning off the coolant and pushing it out the tailpipe. Once operating temperature is reached thermal expansion causes the crack or hole to close and no more leak (which may be why the pressure test passes). The head near the exhaust valve runs a bit more hot natually due to the exhaust passing through the port.
A crack in the head would keep your oil clean (whereas if the head gasket blows it typically blows between the combustion chamber and the oil/coolant galleys which is why you get milky oil).
Any bubbles in the radiator when the engine is cold and you start it up?
1997 Passport EX, 3.2L SOHC, automatic, 4WD, 131k.
Old 01-19-2009, 06:29 PM
Isuzu Guy
I still think I would dump in some stop leak in the rad to see if it fixed it.
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-19-2009, 08:05 PM
when i top the radiator off with the engine cold there are bubbles that pop up and the fluid goes down but I thought that was just the coolant settling...then I add more coolant
Old 01-19-2009, 08:07 PM
Have you used some and it worked without messing any other components up...I havent heard of anyone using that stuff and it worked...
Old 01-20-2009, 12:06 AM
Bubbles in the coolant at the neck of the radiator = compression leak into the cooling system.
For what it's worth the leak sealers claim to work on internal components but I have never had it work. Do you want to take the risk of thinking the problem is patched and then have the plug blow loose leaving you stranded?
Sounds like you have a cracked head. Being that you have two heads I would run a compression test and check the spark plugs. Chances are one of the cylinders will come up lower and/or one of the plugs might be discolored compared to the others.
Old 01-21-2009, 11:27 PM
okay guys help me out here...I had a friend at work pressurize my cooling system. With the oil cap on the system passed the pressure test. With the cap off the pressure slowly began to fall. He said that it wasnt a crack head or blown head gasket cause if were either of the two the pressure would have fell regardless if the oil cap was off or not. He diagnosis was a leaking intake manifold gasket. Something about water jackets running thru the manifold which i didnt think it did. Help
Old 01-22-2009, 12:00 AM
Leaking intake manifold gasket is VERY common on the 2nd generation Rodeo's...so it's a big possibility.
1997 3.2L V6 Rodeo
Old 01-22-2009, 12:34 AM
A leaking intake manifold gasket won't send bubbles streaming into the cooling system.
If you fill up the coolant and start the engine when cold does the overflow reservoir's level rise? Does your exhaust have a sweet smell to it and does the steam linger? Normal exhaust will dissipate quickly when the weather is cold; burning ethylene glycol produces white dense steam that is rather like fog. A spark plug with whitish or brownish deposits on it could indicate the bad cylinder head.
Old 04-08-2009, 11:20 PM
Does anybody know where i can find a diagram of a 98 isuzu rodeo DOHC to find freeze plugs. And also, are they even possible to change out if I locate them?
