Old 03-28-2009, 01:28 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: **abs,trac Off Service Vehicle Soon Lights**
Originally Posted by aznacid View Post
Hey guys,
Quick questions. I replaced the drive side hub, but was I suppose to pack grease into the bearings? I just took the part out and installed it with my teacher doing most of the work.
Cheers!
The wheel bearings in the hub are pre-packed with grease so you do not have to do it. They are sealed anyways. You can clean the old grease of the axle shaft and put a moderate coating of bearing grease on the axle shaft before installing the hub.
Timeslip 08/12/06
AF Community Guidelines
Old 04-08-2009, 10:21 PM
undersc0re undersc0re is offline
I replaced both front hub assemblies 5 months ago, now those pesky lights are all coming on again like they did when the bearings went bad before, except one difference is a while after those 3 lights come on(say 10 min), the emergency brake light pops on(not always)....is this now a problem with the backend hubs?
Old 04-05-2011, 10:58 PM
thyalmighty thyalmighty is offline
Hey everybody
I hope this post can be reactivated because I have a question
I have the same problem now and it is probably because I used a pressure washer to my nice aluminum rims =D
I am able to lift my baby and take her wheels off, can someone tell me whereabouts I can look for this wire?
I hope someone can reply, thanks so much
Old 04-06-2011, 01:26 PM
463's Avatar
463 463 is offline
Originally Posted by thyalmighty View Post
Hey everybody
first off welcome to A/F. it is best to post a new thead if there has been a three months with out a post. this will may result in a quicker response time to you question. the year make and model of auto in question helps in the get to the problem. the connector looks like this http://www.rockauto.com/catalog/moreinfo.php?pk=1841300 here is a dia link http://www.compnine.com/index.php?u=...06&grouptype=B Automotive Forums .com
Old 09-19-2011, 10:40 PM
xtreamdnbfreak xtreamdnbfreak is offline
I am having the same problem with my 04 grand am gt, all 3 of these lights come on either when i turn the car on, or very shortly after. Im also experiencing, that before the lights come on, if they havent already when i started the car, that when i step on the brake, it feels like the ABS is locking up and kind of pushing back on the pedal and vibrating the brake pedal......
Any Help?
