Old 03-19-2003, 07:57 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Originally posted by FourthGenHatch
The thing I don't understand is my Rota weighs 12lbs and the tire weighs 20 lbs. So even if you had a light rim or a small rim the tire is heavier and farther away from the center so why does a small rim really matter as the tire will be heavier.
ur tire weighs 20lbs are u sure it's 20 lbs cause that's a heavy tire
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-19-2003, 08:13 PM
kutsuju racing kutsuju racing is offline
the reason the overall diameter also hurts you is because it changes you gear ratio's as well....for example I'm running a DX tranny on an Si motor....(old redline was 6,800) new motor is (7,200) with 17's on my shift point from 3rd gear to 4th gear was about 90-92 mph normal for a honda well now with the new motor 400 more RPM's now I shift at like 105 from 3rd to 4th....but at the track with my 13's on and at about 22PSI I shift at about 98 or so....
it's kinda like changing gears on your old ten speed! going from the big gear to the little gear....you want to go faster you go to the smaller gear...you want to drive easy....the big one...
Weight is a huge robber of power on our cars....I picked up .2 by gutting my car. that's about a car length to car length and half at the track!
Peter S.
www.kutsujuracing.com
Old 03-19-2003, 08:16 PM
doug294 doug294 is offline
Send a message via AIM to doug294
true
The exhaust statement is completely wrong. I have my cat gutted out and I can tell a power increase. My motor has more pull because it is able to breathe better.
Old 03-19-2003, 08:47 PM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
My friend with his 91 Civic 4 door got the cat, resinators off, and had the pipping upgraded to 2 1/4 all the way form the stock manifold back. His car is a LX, wich is the 90 hp dual point 1.5. He said (and it is true, cuz I rode with him) that he could chirp 2nd gear pretty good, as where he never could before. He said he noticed a BIG difference in power. His car sounded like pure ass with no cat, but that is just a sacrifice you will have to make to have a fast car... well if your motor is stock anyways. Eventually he got tired of the sound that his car made, and had 1 resinator put in... looks like a catilitic converter if you look under his car. Anything bigger than 2 1/4 pipping you will be losing backpressure, as you were saying in the last posts.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 03-20-2003, 06:16 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
dood some people needa read that large ass explanation of exhaust they have floating around AF somewhere. backpressure is bad no matter what. its delta pressure you want, which technically measures the absence of pressure between exhaust pulses, AKA scavanging. i say gut your cat, weld a pipe inside it (making it look like a cat but function like a straight pipe) then get straight 2-1/4" or 2- 1/2" stainless from your new "cat" to the back, but dont let them make the "bend of death" around the gas tank. instead of running it like the stock exhaust, run it without so many 90 degree bends, just go around the gas tank and come straight out the back on the passenger side, or go the other way around the gas tank and come out on the drivers side (although with this you are gonna needa do a lot of heat shielding cause your gas lines run on that side too)
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-20-2003, 08:15 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i tried running my exhuast striaght out the drivers side, but there were too many complications on that side, so i just run mine straight out the pass side.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-21-2003, 11:49 AM
civic89dx civic89dx is offline
Send a message via AIM to civic89dx
whether a cat is good or bad for your engine doesn't F*CKING matter. it is there for a reason and that reason is to keep harmful sh*t from going into the air. don't be another dickhead polluting the world. seriously, is it worth that extra little HP. NO.
1988 Black Honda CRX Si
