Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-19-2008, 11:33 AM
v8_ranch v8_ranch is offline
Re: 97 Suburban - transfer case will not shift
Looks like I will be purchasing the alldata deal. Once I have it, is there a section or area I should look at specifically for my problem. Just wondering what to expect from it.
Thanks
Old 10-19-2008, 11:36 AM
looks like I will be getting the alldata sub. Once I have it though, is there a particular area if it I should go to look at more info on my problem? Just wondering what to expect from it... thanks!
Old 10-19-2008, 12:16 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Go to powertrain/transfer case repair and testing info.
You may have to look around a little but.
It should all be in there.
Good Luck
MT
Old 10-19-2008, 12:20 PM
Good Luck
Yeah, looking around now.
Is there an easy way to test the TCCM?
Old 10-19-2008, 12:49 PM
OK, another question...
I am confused about the actual locatino of the TCCM. One diagram on the alldata site showed it behind the instrument cluster somewhere. Another thing I looked at made it sound like it is behind the pax side kick panel. Does anyone know the rigth location. I want to make sure I have a good connection to it.
Old 10-19-2008, 01:02 PM
OK, I have a new update...
Apparently, you cannot use the pin 4 for ground. Does not make sense to me being that is is a chassis ground, but I looked at everythign again and saw that pin 5 was a signal ground. I decided to try pin 13 grounded to pin 5. I have the 2 flash code doing it this way. Does this mean the drive motor is bad? I looked through some troubleshooting stuff on alldata, but afraid the part about the codes is more confusing at this point as they list A codes, B codes, and C codes. I guess you have to have the right scanner for that to be of help. Is what I am doing here definitive at all. Wife is supposed to leave Wednesday morning for South Dakota and I would feel better about her having 4wd for trip.
Thanks all.
Old 10-19-2008, 04:06 PM
j cAT j cAT is offline
Originally Posted by v8_ranch
if no codes, could it still be the motor? Does the fact that there are no codes tell me anything good about this situation?
try this site :http://www.blazerforum.com/m_56175/tm.htm
Old 10-19-2008, 06:47 PM
777stickman 777stickman is offline
This is out of my '98 C/K service manual.
DTC 2 = "During electronic shifting the TCCM checks the encoder/motor for normal operation. If the encoder/motor does not function correctly enough times the TCCM stores a motor/encoder failure DTC2".
Have you tried to shift the t-case to see what happens? It's possible you may have reset the electronics when you disconnected the Batt.
DLC pin 4 should have given you a good ground for the test. You may want to test that pin again for a good ground and we may have to address an issue with that!! Pin 5 is a ground source for the VCM.
Also need to look at the wiring connections at the motor.
Otherwise, sorry to say, you're looking at replacing the t-case encoder/motor.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-20-2008, 09:21 AM
Thanks all.
dtc 2 usually means a shorted out encoder motor...this will also come up if the motor is open or if the motor is not moving as commanded.
obviously anytime an electrical device has issues wire/connectors must be inspected ...but you will be doing that any how..
now the search . the quest for the cheapest supplier....One hint:It won't be your local chevy dealer....
