Go Back   Automotive Forums Car Chat > Automotive Art > Car Modeling > WIP - Muscle Car / Hot Rod
WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum.
Old 09-27-2008, 02:36 PM
stormer_GS's Avatar
stormer_GS stormer_GS is offline
Re: WIP: Revell Cervini Mustang
A huge change thanks to Mikezibit! I got the real wheels for my Eleanor!!
It's time to move on soon because it has to be finished before 18th of october. We have a local contest,
sponzored by Revell on that day.
Old 09-28-2008, 05:52 AM
mrawl's Avatar
mrawl mrawl is offline
Great effort. That's a lot of work you're putting into this, looking forward to seeing you bring it home.
Mark R
Old 09-29-2008, 09:03 PM
DressedtoDepress's Avatar
DressedtoDepress DressedtoDepress is offline
Looking very good. I'd love to get a set of those wheels.
Old 10-01-2008, 06:03 PM
stormer_GS's Avatar
Thanks guys!
Here's a little update - nothing much but it's moving on, right?
I glued sideskirts to the body other than that didn't change much. I've got a lot of work with
putty and body patching.
Old 10-01-2008, 06:11 PM
stormer_GS's Avatar
By the way...
Does anyone have a diagram (how it is mounted) of a procharger? I'd need it for this beauty.
Thanks!
Old 10-02-2008, 03:25 PM
ketje's Avatar
ketje ketje is offline
Looking great. Keep it coming
Old 10-11-2008, 02:55 PM
stormer_GS's Avatar
Thanks for comments!
HI!
I'm back with a little update. I had to widen the fender on the left side to match the right side:
The thing that looks like gap in the fender is the CA gel glue.
Evil look:
Sexy back:
Still have to fill the small gaps on the body before priming.
Hope to post some progress soon.
Old 10-13-2008, 12:46 AM
stormer_GS's Avatar
I managed to prime the body, so it's ready for stage 3 - tamiya basic putty:
A lot of scars on it but I'll fix them.
Old 10-13-2008, 06:22 AM
GvEman's Avatar
GvEman GvEman is offline
Looks awesome! I would build a saleen compressor kit instead of a pro charger.. my friend got a saleen one and it looks so awesome irl!
Keep up the awesome scratch building!!
Best Regards
Anton
Old 10-18-2008, 09:19 AM
white00gt white00gt is offline
Great build, btw where did you get the wheels for this would love a set , also would love a set ofthe cervini wheels- after your done you may want to have the parts cast in resin sell it as a add-on kit I know I would buy it.....
Old 10-19-2008, 03:36 AM
mrawl's Avatar
You wanna be careful with that basic putty - it shrinks slowly for weeks as it dries, and can ruin your painting with shrinkage and lines if it's not fully stable. That's why people use the two-part stuff - it's more stable, better for sanding, painting and finish work. You probably know all this, but anyway, keep up the good work, it looks really good.
Mark R
Old 10-19-2008, 11:43 AM
You can also seal with future floor polish before painting - avoids "Ghosting",works very well
Old 10-19-2008, 11:56 AM
ZoomZoomMX-5's Avatar
I think you are confusing two completely different causes of "ghosting".
Future or any sealer won't avoid "ghosting" if the putty used isn't 2-part that cures by chemical reaction vs. air drying of standard putty. Shrinkage is shrinkage; regular putty takes months to fully cure and shrink, 2 part putties are cured in minutes/hours. Using a sealer doesn't stop standard putty from shrinking. Sealers are used to keep the solvents in the paint from reacting w/the plastic around fillers and where bodywork has been sanded/modified. It's the swelling of plastic around bodywork where the ghosting occurs in that case.
My Fotki Album
Old 10-19-2008, 06:00 PM
I blame my keyboard for that(that's my story and I'm sticking to it -lol)
I meant after shrinkage and part is ready for primer Future helps , when I use it there is no ghosting(body filler showing up through primer)
Old 10-22-2008, 07:23 PM
stormer_GS's Avatar
Thanks for all the helpfull tips, guys!
Well I applied putty two weeks ago so it should be ready for sanding soon. Hopefully I will post some progress soon.
I did some work on the engine and now I'm working on fitting a 9V battery under the rear seats for
lighting of this baby. I have also started with modifying of the wheel arches so that the rear wheels
will fit perfectly. That also required making of a new differencial...
Pics will follow soon!
Thanks for watching! 8)
