Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-30-2008, 04:06 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Houston, We Have A Problem - Project "Green Machine"........
Shiney like new!
Just a thought, if it hasn't been replaced already, why not do the timing cover gasket while you have the P/S pump and alt off? I've seen a number of 3.1/3.4 that go soft around the coolant passages, it might save ya some time in the long run
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
  #17
Old 06-30-2008, 05:00 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Yeah I will change it and the timing chain/gears in the next few weeks .
I was going to now, but I need a bunch of stuff I dont have here in my garage at home. I'll take it to the shop and it'll be so much easier and faster. Plus the front main needs replaced and probly the oil pan....man this job keeps getting bigger and bigger.
Been having a hellofatime getting the cam sensor out. Wires are all bad, previous ower tried silicone on them. That would explain the random DTC I got last year for the cam sensor. Its soaking in WD now so maybe later it'll just pop right out.
Not in a big hurry, the weathers been great so I'm taking advantage of that right now, cruising in the SE @ $4.35 a gallon for premium. yee haa !
edit...
After going over the heads I find they arent warped but several valves are leaking... badly!
So looks like a small valve job nothing to radical for the daily driver, save some gas.
Getting ready to check the timing cover more closely......
1999 Grand Am SS 3.4 OHV
  #18
Old 06-30-2008, 09:35 PM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
you should look into and see if any company makes aftermarket valves, same dimensions of coarse
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
  #19
Old 06-30-2008, 10:06 PM
Oh yeah thier are many brands and types, stainless is what I'll probly use, I just happen to have a set for the 3.4.
I inspected and cleaned the oil pan this evening, doesnt look like the pan or main has been leaking, to my surprise.
A couple years ago the heads and intake were leaking, but thier is no new/fresh oil anywhere. So I will clean it up the best I can, and see what it looks like in 600-700 miles.
I swear, GM loves those push pins and 10 mm bolts/nuts.
.... things are definatly up in the air. lol
Oil pan was realy dirty, my GT didnt have any of the under panels(splash shields) , I replaced them all but never cleaned anything.
Before....it all looked like this.
Looks better now.
  #20
Old 07-01-2008, 02:58 PM
I finaly got the camshaft sensor out lastnight....
Its bad, and the cheap plastic kept breaking off ! lol
  #21
Old 07-01-2008, 03:34 PM
J-Ri's Avatar
I bet that was fun!
  #22
Old 07-03-2008, 11:52 AM
Yeah as fun as a bees nest. lol
Heads are ready to slap back on, I'm hoping to get it togehter this evening and fire it up in the morning.
Still need to get the old cat off, pipe and clamps rusted good, looks like time for the plasma cutter.
  #23
Old 07-03-2008, 03:13 PM
J-Ri's Avatar
I wish I had one of those, so much better than the ol' oxy-acetylene torch
You better replace the exhaust and hardware with stainless so that doesn't happen again
  #24
Old 07-04-2008, 02:24 PM
Yeah its a cheaper Esab 650 only about $1200, it's done paid for its sell in time/labor costs.
Heads are on, though I've hit another road block due to the holiday.
I didnt have all 12 of the exhaust manifold bolts/nuts, and not all of the LI bolts. I called the local stealershits yesterday and they wanted $48 for the 8 LI bolts and I forget about the exhaust stuff.
Luckily my local NAPA ordered them for me, wont be in untill saturday morning.
Taking the week-end off I think on the GT. Going to a BBQ and getting drunk , watch some fireworks and such.
And run the DS outta the SE, see if I cant finish off my tires.
  #25
Old 07-05-2008, 05:36 PM
Well I didnt get to smashed and I got the headers on this afternoon.... major PITA !
I'll post better pics later.
  #26
Old 07-05-2008, 10:06 PM
Thumbs up Houston, We Have A Problem - Project "Green Machine"........
Ok, its later .
Finaly got them on, and tight!
Some of the new studs I purchased were about 1/4" longer, and the nuts were crimped lock nuts, which made things go very slow. Could not get to one nut , and I finaly got a 1/2" boxed end wrench(when its 13mm) to fit after some bending of the wrench.
I dont see how anyone could actualy torq all these nuts, you cant even get a ratch down there.
Any who here's some pics !!
Rear Header-I think the lower heater hose is to close to the rear header pipe so that'll need modified.
Front On
Front, front
Rockers and Push Rods intact... and ready.
I would have it done but I dropped and broke my smaller torq wrench, that's in Inch lbs.
I give Bob kudos on this install, and thankx for those tips on the front, it was very very tricky!
  #27
Old 07-06-2008, 12:26 AM
Gir-_-'s Avatar
so XI, you're just rebuilding it correct? Not putting MMS stuff in?
  #28
Old 07-06-2008, 10:50 AM
Yeah prety much stock. I did use better valves & keepers.
Oh yeah , my Grand am love! Who says they dont have heart.
  #29
Old 07-06-2008, 02:23 PM
J-Ri's Avatar
$1200's not bad at all, they were much, much more the last time i saw any prices on them. I'll have to see if I can get my boss to buy one of those plasma cutters.
Yeah, vinyl locknuts may not work too great on exhaust
  #30
Old 07-06-2008, 11:35 PM
Thumbs up Re: Houston, We Have A Problem - Project "Green Machine"........
Well things are getting closer to being done, just taking my time, dont want to mess up my paint! lol
Worked all day at the shop then I go and do this 10 minutes into it...... smashed my right pinky cutting the nail into.
OK, On with the pics
The header cross over is realy close to the thermostat housing.
Its starting to look like an car again!
Closed Thread
