Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-27-2008, 06:48 PM
j cAT j cAT is offline
Re: ethanol
Originally Posted by Blue Bowtie
I'm storing lawnmowers, a chainsaw, two snowblowers, a two-stroke trimmer, a DR brush trimmer, an outboard, several cars, and an emergency generator with E-10 and Sta Bil. They all seem to work fine every season. Here's a hint from 20 years experience doing this - Prepare the engine(s) as you normally would for storage, with oil/filter changes, plug cleaning, etcetera. Try keeping your fuel tanks for storage only about half full, add the recommended amount of fuel stabilizer for that amount of fuel and just a few squirts more, then add two stroke oil to make about a 100:1 mixture. Run the engine briefly, fog the cylinder(s), and it should be ready to go the following startup.
i agree with all that you stated, and have had no problems until alcohol began to be added....use sta-bil when gas is purchased every time also add small amout of marvel oil to gas 1/2 oz/2 gallons...many years no problems in spring lawn mower starts every time ..lawnmower is 1992 snapper tecumseh..
you mention the E -10 what's that...?
Old 05-27-2008, 07:12 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: ethanol
E10 is another way of writing "Gasoline, 10% ethanol content".
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-27-2008, 08:37 PM
Blue Bowtie's Avatar
Registered Offender
Re: ethanol
My mower is a 1988, Briggs 5HP Quantum. It's had E-10 from Day One. I've installed a new plug now and again, changed oil, replaced two worn front wheels (from rolling in grass for 20 years), and the blade brake cable wore out last year, but nothing else. It also runs two blades just to load up the engine a bit more:
Ditch the Marvel Mystery Oil, run 10W30 Mobil 1 or Amsoil in the crankcase, and mix the storage fuel as described and it should be fine.
