Old 05-01-2008, 05:52 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Tank tracks?
that and a bobcat (i believe) has the hydrolic trannys to allow the independant movement of the tires seperately.
Old 05-01-2008, 09:10 PM
Ethan Jay Ethan Jay is offline
Re: Tank tracks?
Originally Posted by KiwiBacon
There are some very obvious reasons they won't fit on a car. You shouldn't need us to point them out.
Well how about installing wheels that fit Bobcat tires, seating and installing the tires, and then mounting tracks (with the proper amount of shoes to fit the wheelbase) over the tires?
Old 05-01-2008, 09:26 PM
GreyGoose006 GreyGoose006 is offline
Re: Tank tracks?
look buddy, there is a thing called a body in the way.
on a car or truck, the wheels fit into the wheel well, which makes it so that they dont stick out from the car.
http://image.superstreetonline.com/f...-side-view.jpg
http://image.automotive.com/f/cuvs/2...-side-view.jpg
http://www.trustmymechanic.com/auto-...resideview.jpg
see!!!
you would need to first lift the car like this
http://image.minitruckinweb.com/f/mi...fted-truck.jpg
http://haxadecimal.com/nucleus/media...4643969359.jpg
then install a hydruaulic motor at each wheel
then install a hydraulic pump where the transmission used to be
then reinforce the suspension so that it didnt buckle under the tension of the tracks
then have a completely useless car because by the time you lift it that high, and put all that extra stress, weight, and complexity into it, it will break or tip over when you take it off road.
Old 05-01-2008, 09:39 PM
Re: Tank tracks?
What if I took the body off and made a new one, which actually looks like a tank body?
Old 05-01-2008, 10:50 PM
KiwiBacon KiwiBacon is offline
Re: Tank tracks?
A car is completely the wrong platform to start with.
A four wheel motorbike (ATV) is better, but not by much.
Just buy an argo and be done with it.
Old 05-01-2008, 11:31 PM
Re: Tank tracks?
I'd like something a bit bigger. Maybe I should start a "how to make a tank" thread?
Old 05-02-2008, 01:17 AM
Re: Tank tracks?
Old 05-02-2008, 04:28 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Tank tracks?
Listen... what you are asking is like saying; "can I make my pidgeon look like a giraffe?" The answer is yes, but it requires veterinary surgery, glue, prayer, and years of patience.
I truly applaud your enthusiasm, but as someone who has worked on Bobcats, tanks, cars, and everything in between, I have two words for you... Holy F**k. I have been customizing cars and trucks for nearly 20 years as well as having many years experience operating skid steer loaders and track loaders. The kind of modifications you are proposing are beyond me.
Let us know how it goes.
Dragging people kicking and screaming into the enlightenment.
Old 05-02-2008, 04:52 PM
Re: Tank tracks?
Maybe I should try a different approach...
Old 05-02-2008, 04:56 PM
Kind of a Big Deal
Re: Tank tracks?
maybe you should try giving us your goals and what youre trying to accomplish. then we can give ideas on the best way to go about it.
