Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-23-2001, 11:54 AM
MAXIMASE2000 MAXIMASE2000 is offline
I just installed my Stillen Intake. I also installed my strut tower brace and rear sway bar. Here is a pic of the intake CHeezy I know
How you like your Stillen intake? Sound louder too.
MAXIMASE2000
STILLEN AIR INTAKE
PIAA H4 SUPERPLASMA
SUPERWHITE TURN SIGNALS
CLEAR CORNER LENSES
20TH AE DOOR SILLS
WOOD DASH
Old 10-23-2001, 08:01 PM
riceburner riceburner is offline
The Stillen intake made some power. I did notice an improvement in throttle response. I have all of the exhaust components (y pipe is on back order but should be here this week) I really believe that I will not really get the potential until I add the other components. I would probably notice a bigger difference if I put the intake on last. As for the noise, Normal driving doesn't bother me. Yes it is a bit louder. But only at WOT is it real noticeable. But that's ok.
I plan to have the full exhaust system (y pipe, random tech cat, b pipe and rear section) installed next weekend I will let everyone know what I think for whatever its worth. :licker:
Old 11-07-2001, 09:13 PM
MaggieMax MaggieMax is offline
ricey, if you want to make those tailights a little more pallatable you should try tinting the inner face of the clear plastic case. they really need to be toned down a little. i like a few altezza's that i have seen but just not for the maxima. the maxima taillights are just too big for that style and the big red brake lights really take away from the subtle styling of your amazing car.............
that's just my two cents.
nismo rules,
honda drools,
war max,
i'm out
Old 11-07-2001, 11:54 PM
black019 black019 is offline
skyline tails!
High Octane Boards - Members Wanted
http://www.mnbmotorsports.com/forum
Old 11-08-2001, 08:29 AM
uh......yea if you can get them, and afford the conversion.
nismo rules,
honda drools,
war max,
i'm out
Old 11-08-2001, 01:24 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
yeah what he said.
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 11-08-2001, 07:18 PM
bmw headlights!
Old 11-08-2001, 10:55 PM
Nizmolee Nizmolee is offline
Send a message via AIM to Nizmolee
Hey bro, Im on the WestCoast, so if you are in LA area lemme know. we can exchange ideas. The LEVOC shifter works for the auto, i have an auto max. also the razo works too but the levoc is a lot nicer.
98 Auto NOS Maxima.
Old 11-21-2001, 12:36 PM
madmax26 madmax26 is offline
Send a message via AIM to madmax26
ground controls
how do they ride and how low do u have them set, and how the shocks holding up
1995 Maxima SE 5 spd. :smoka:
Old 11-26-2001, 01:00 PM
ground controls
I have the rear set all the way to the top. Which is about an inch drop I think. As for the front, I have played with lowering the fron 1.75 to 2" from the top of the ground control collar. If I read the literature correctly, the drop is from 1" to 4" so the front drop is about 2.75 to 3" drop in the front. As for the shocks. There doing ok but I highly recommend using aftermarket. I am getting the KYB AGX (on order soon) The problem with the factory struts is two fold.
1. the higher spring rate of the gc make it a little bouncy over big bumps. Higher damping shocks will improve this.
2. The factory shock are too long (cannot be lowered) too much or the piston bottoms out. The first time you hear this it will scare the $hit out of you. ( I noticed when I drop my car lower.) I noticed the handling is better when the front is lower than the rear. but that could be just me. If you lower your car more that what I said, you will bottom out in hard cornering on smooth surfaces.
Now for the the good news. The ride is great on the freeway. It only is a little ruff around town with the bad roads. I go over railroad tracks with no issues and I don't slow down too much for them. The car does not lean too much and does not dive at all in hard breaking.
The stiffer shocks will actually improve the ride quality. Its all about balance. (at least that's what Mr. Miyagi says)
95 Maxima SE (All mods done myself)
Check out my website @ http://www.maximacar.com
Performance Mods
Stillen Intake, Y-Pipe, B-Pipe, Rear Section, FSTB, RSB and Camber Plates
Limited Slip Diff (from I30 auto)
GC Coil Overs
Fiber Images Carbon Fiber Hood
Stereo Mods:
Concept, Sony, Orion, Eclipse and lots of Dynamat Xtreme
Old 12-08-2001, 01:40 AM
mohfo mohfo is offline
Air intake
where did you attach the air mass sensor? I have some generic intake that didn't come with a anything to put the air mass senor.
Old 12-08-2001, 10:42 AM
NJMAXSELTD NJMAXSELTD is offline
Leather Seats
There's a web site, leatherseats.com I believe. They have some really nice leather packages for the Maxima. Two tone and all. Simple instructions to remove your cloth and install the new leather. That should jazz up your interrior.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 12-10-2001, 06:49 PM
Re: Air intake
I have included a pic below. The Stillen intake has pre-drilled holes for the temp sensor. I hear that was not always the case. You could drill three small holes in the end of your air filter intake assuming it is a cone type. Make sure to do this off the car. You do not want to have any metal filings in the intake track
I have documented this install on my site with some pics at www.maximacar.com go the the tech section under what else "Stillen Intake" use the menu on the left to navigate. :flash:
Performance Mods
GC Coil Overs
Stereo Mods:
Old 12-12-2001, 10:15 AM
MaxRX7's Avatar
stick the biggest K&N you can find in there !!!
