Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-09-2008, 10:30 AM
95cavspeed's Avatar
95cavspeed 95cavspeed is offline
Re: Turbo problems <STOCK>91 eagle talon TSI
thanks i think your right, well my turbo says TDO5H, sumone told me that means its a 16g? is that right, and yeah im runnin off the stock boost gauge
Old 03-09-2008, 02:06 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
get an aftermarket boost gauge, you may be hitting fuel cut causing the ECU to do what it needs to do to keep the motor from going "BOOM" so... be careful, i would try to keep it out of boost untill you find out what turbo you are running, where the boost is set, and get a decent set of plugs in their... then you can have some fun
Old 03-10-2008, 11:30 PM
bryan_bigd's Avatar
bryan_bigd bryan_bigd is offline
yea i agree i would not run it hard intill you get a gauge. but buddy has a 350 z and we put a turbo on it. well he did not have a gauge and the turbo said that it would auto set at 8 pounds. well he blew is motor and we replaced it and hooked up a boost gauge he was running like 25 psi. cost him 4k. so be carefull.
1995 talon tsi 10-26lbs of boost boost controller k&n intake 550cc injectors 255 fuel pump ported head 3 angle valve job hks metal head gasket arp head studs racing manifold evo3 16g ported turbo 34mm wastegate 3in turbo back exhaust no cat act 2600 clutch 7.9 lbs fly aem 9.3 plug wires irradom plugs lowered 2 in camber correction all four wheels 2 3/4in upper intercooler pipe greddy rs BOV racing hard intake pipe apexi NEO fuel manigment system oh and it has the 6bolt motor
Old 03-10-2008, 11:33 PM
bryan_bigd's Avatar
oh and tdo5h from what i understand is the size of the turbo housing. not the turbine or the wheel.
Old 03-10-2008, 11:37 PM
steviek's Avatar
steviek steviek is offline
Haha turbo's auto set at 8 psi. Who gave you that timbit of information>?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-11-2008, 07:30 PM
95cavspeed's Avatar
ok need some help i checked my trubo out, and were the 4 bolts are on the manifold that hook to the turbo in that housing there is a 1 inch hairline crack, is that why my cars so slow? and when i went to push in or out on the wastegate it would not push in and took alot of strenth to pull it out is this mean thats ok?
Old 03-11-2008, 11:00 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
A cracked 1G manifold is common. Either find a 2G or EVO III manifold. The crack will only get worse so if it's not big enough to hinder performance now, it will be in the future. The wastegate actuator arm won't move very easy by hand if working properly.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-14-2008, 08:57 PM
bryan_bigd's Avatar
hey dude take the pen out the the waste gate that connects to the turbo and see if the little peace that the wastegate hooks to will turbo. it should turn easy as long as the wastegate is not hooked. if it does pull the wastegate hard as hell and it shold pull. if you have any problem let me know i have a 2g exhaust manifold il sell. also i have a t25 turbo and some other shit for these. im about to sell my awd talon. kids.
Old 03-15-2008, 10:52 AM
95cavspeed's Avatar
yeah i did that stuff the wastegate arm is hard to pull but it does, and i took the pin out the little things moves real easy.
Old 03-15-2008, 01:25 PM
steviek's Avatar
dude I have an extra 2g mani if you want
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-15-2008, 12:44 AM
nissan240sxdrift nissan240sxdrift is offline
Could i use the 2g manifold u have on my stock tsi .....if so how much do u want for it???
Old 07-15-2008, 06:39 AM
steviek's Avatar
yes you can but I sold it already for 40 bucks
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 11-19-2009, 08:20 PM
spokkez spokkez is offline
maybe u guys can help me out.i have a 1995 eagle talon tsi and when i first bought it the turbo would it at 3000 rpms and it would just fly through the other rpms.but now i punch it and it feels so slow.i changed the gasket from the header to the turbo and i changed the gasket on the down pipe.im running platinum iridium plugs.ive had them for like 2 months.u think i fried them already or i just might need a new turbo?
Old 11-19-2009, 09:57 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Welcome to AF, glad to see your using the search feature and looking at older threads but you should have made a new thread ab your problem.
I would check for boost leaks if I was you. Thats usually a good place to start. Search on google and you can find out how to build one cheap.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-20-2009, 07:38 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Copper plugs only. Ditch the snake-oil plugs.
Kris
2012 Genesis Coupe 2.0t
