Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 03-11-2011, 10:41 AM
osteve150 osteve150 is offline
Re: Passenger Floorboard Wet
update in case anyone is still following this... the cowl drain was not clogged this time... so i pulled the glove box out, unhooked the wiring harness and removed the engine control computer and cut out as much of the insullation as i could. I poured water down the windshield and followed the small leak up to a point where the firewall meets some other body componants and had some body sealer between - the body sealer had formed a hole not much bigger than the tip of a pencil ( attached picture) sealed the hole, hopefully it holds.
The Following User Says Thank You to osteve150 For This Useful Post:
Brian R. (07-02-2013)
  #17
Old 07-02-2013, 02:16 PM
FLToyAvalon02 FLToyAvalon02 is offline
osteve150, did you resolve your leak issue from 3/2011 posting?
My symptoms appear to be very similar to yours and I am hoping for some wisdom and success...Can you share either?
I have No Sunroof, it is Not a/c drain line, only gets wet when it rains, regardless of moving or sitting still and the water settles/pools in the passenger side rear floor pan.
Thank you!
Old 07-02-2013, 02:27 PM
Wow totally forgot I had this issue! Yes peel the carpet back remove anything that prevents you from getting a good look at the firewall and inspect the inside of the firewall I had a pen sized hole that I sealed with silicone sealer and never had another problem! I ran water over it with a garden hose while everything peeled back to find the drip
  #19
Old 07-02-2013, 02:58 PM
Thanks for the quick reply!
That should help when I dig into it. I have started with only checking window and door seals but have not found anything yet.
I will check the front carpet padding more closely and see if I can find anything around the firewall where you did.
Was your carpet only wet in the front floor board, or did the water eventually accumulate to the rear floor pan to settle at the lowest point?
Thanks again!
Old 07-02-2013, 05:24 PM
Yes it would seep to the rear and sometimes be worse there because its a little lower than the front floor pan. Good luck!
Old 07-27-2014, 10:56 AM
gibbons14 gibbons14 is offline
I have a 2000 buick century and the rear passenger carpet gets wet after it rains not the front passenger carpet
Old 07-27-2014, 02:36 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Pull the carpet in that area and look for a hole in the floorboard.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
