Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 01-21-2008, 01:02 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Only Getting 6 Volts, Need 12
How old is the amp? Does it go into protection mood or will it not get any power?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 01-21-2008, 01:53 PM
EclipseG13 EclipseG13 is offline
The guy at Stero Shop said the power line was only feeding 6v and it was most likely the fuse.
I just replaced the whole thing and got a new fuse box with an 80A fuse in it. I bought the AMP last year, used it for a month, and then I sold the car it was in and it has been sitting in its packaging on a shelf in my closet since then.
UPDATE
I just had a small breakthrough with it. I was playing around with some settings on the back and it lit up. All the blue LEDs came on, and it did not go into protected mode. It stayed on for litleeraly a second but the ground wire slipped out. There was a lot of tension on it so I am checking that right now.
Old 01-21-2008, 02:23 PM
Well, I now have power to the amp.... It lights up and its not in protected mode but, the subs are not hitting. I played around with some settings on the amp and the head unit but still a no go.
Any ideas?
Old 01-23-2008, 09:47 PM
JoeShmoe's Avatar
Any ideas?
How hard did you expect it to hit?
Old 01-23-2008, 11:29 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Do the speakers work at all? Make sure you have the positive and neg. hooked up correctly. And also that you have the correct ohms going to the speakers and amp.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-24-2008, 06:40 AM
JoeShmoe's Avatar
Bingo, make sure they add up. I used to run shit willy nilly but after learning a bit more about electronics i quicikly shanged my whole setup.
Old 01-24-2008, 03:33 PM
Got it, I found to other leads comming up from the wheel well... Plugged em in the amp and boom!
Can hear me coming from miles... lol King kong in tha trunk.
