Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-17-2003, 03:55 PM
sadlerb_98's Avatar
sadlerb_98 sadlerb_98 is offline
Send a message via Yahoo to sadlerb_98
I just pulled down the cover again and saw the plug-in. What is the going rate for the reprogramming? Just so I will know how much I need to set aside for it.
thanks a million
bobby
Old 02-17-2003, 03:57 PM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
around here somewhere around 35 bucks.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 02-17-2003, 03:59 PM
sadlerb_98's Avatar
awesome. That is not too bad.
thanks,
bobby
Old 02-17-2003, 04:10 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Is that for .5?
Old 02-17-2003, 04:20 PM
We charge .5 but you know I don't even know our labor rate
Shop Foreman
Corvette Specialist
L1 Certified
Old 02-17-2003, 04:25 PM
Blah blah blah
LOL I did'nt know ours either but had to ask, we get 90.00 an hour, but thats Scottsdale AZ for you.
Old 04-03-2005, 02:28 PM
zetapsi538 zetapsi538 is offline
2002 keyless entry
My problem is so close to this I had to post here. My wifes 2002 Blazer came with Keyless entry code AUO or whatever, but it has an aftermarket keyless entry module installed in it as well, the OEM one has been removed. After I put in a GM moudle and pull this aftermarket one what needs to be done?
Old 05-03-2005, 01:46 PM
KindOfBlue KindOfBlue is offline
Re: How to tell if I have keyless entry 2002 Blazer LS
Originally Posted by Shortbus@AF
It is OEM and at a great price to only 9 dollars above GM cost on them. They probably bought into a large quanity like we do.
That link is now dead, but I've found the VKE 1000 at www.oem-auto-accessory.com for $145. Is that a reasonable price?
Old 03-09-2007, 11:30 PM
tazl3oy tazl3oy is offline
can someone help me i have a 03 blazer and i dont know if it has keyless can someone help me out thanks alot... vin # is 1gndt13x63k134549
Old 03-10-2007, 09:56 AM
maxwedge maxwedge is offline
A990 racer
Welcome to AF. LS, this was not factory std. You should have posted this Blazer forum. Check with a Chevy dealer for the rpo code and check the codes in the glove box. Also this thread was 2 years old, start a new one on the future
Old 10-13-2008, 07:21 PM
step1984 step1984 is offline
I'm looking to buy new keyless remotes for my 2002 Chevy Blazer. The remote I have stopped working and I changed the battery so that's not the problem. I am looking on ebay and finding some with the same numbers on the back of the remote, so those should work also. But there are others out there that say they work for the 2002 chevy blazer and the numbers are different. 2 question.
1) Will different remote numbers work on as well? (Same look, just different GM/LEAR, FCC ID, and CANADA numbers)?
2) If I bought 2 remotes, (one with numbers that match the current remote, and one with numbers that are different) will both remotes work if programed?
Old 01-25-2013, 12:34 PM
jlpyles jlpyles is offline
hello,
john
is there anyway you can help me figure out which remote i will need for my 01 blazer ls.
vin # 1GNDT13W212146430
looked under dash and there is a black box.
FCC# KOBUT1XR
15732806 is also on it.
