Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-03-2001, 10:29 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
get the struts and springs first. if from there you dont like the handling characteristics, you can always opt for a rear anti-roll bar.
don't change the front anti-roll bar. upgrading the front will encourage the vehicle to understeer. todays FWD cars are already dialed in with a bit of understeer, as your average driver has a harder time controlling an oversteer situation. upgrading the rear will decrease understeer.
the general rule is a stiffer rear end/softer front will create oversteer... the exact opposite will cause understeer.
Old 01-08-2004, 02:38 PM
NINaudio NINaudio is offline
Re: Shocks and Springs for 2001 Accords
Hey Dezoris, I was looking into some sway bars for my 98 accord. I'm also looking into the H&R cup kit for the car. Do you think that if I were to do both the cup kit and the sways I would lose traction? Or should I do the cup kit only? Also, do you think with my car will I have to worry about subframe tear away if I get a larger sway bar? Will I have to worry about wheel bearing issues since the cup kit will only drop 1.5"?
Old 01-14-2004, 09:18 AM
bump
